Larry G
#1 Posted : Thursday, August 12, 2010 9:41:14 AM(UTC)
Larry G
How do you remove the Lid Switch? What is the part number for the Lid Switch?
Joe / APP Team
#2 Posted : Thursday, August 12, 2010 11:20:06 AM(UTC)
Joe / APP Team
Larry,
Access to the lid switch assembly is through the control panel.
Unplug the line cord first.
Remove the 2 inner screws on the corners of the top of the control panel trim and pull the top towards you.
The lid switch is mounted with 1 screw that you will need to remove in order to lift and remove the tabs from the slots in the top.
When you install the new switch assembly, make sure the metal tab sticking up through the top has to be between the plastic switch body and the button of the switch.
Open the lid 1/4 to 3/8 of an inch,and slide the assembly towards you until the button clicks and secure the assembly in place(tighten the screw).
Now switch the wires from old to new switch, reinstall panel and test operation.
Part number: AP4026359
:) :cool:
lid switch replacement (Washer Repair)
by thosman 5/10/2011 6:55:50 AM(UTC)
Lid switch replacement (Washer Repair)
by timberwolf 4/13/2011 9:12:28 PM(UTC)
by quinnmiano@email.com 10/12/2010 4:33:39 PM(UTC)
older whirlpool lid switch replacement (Washer Repair)
by crmb23 6/6/2010 6:34:17 PM(UTC)
Stackable washer lid switch replacement (Washer Repair)
by tmealy 8/18/2009 10:22:32 AM(UTC)
Whirlpool washer lid switch replacement (Washer Repair)
by lordmandy 7/27/2009 5:50:25 AM(UTC)
Lid Switch replacement (Washer Repair)
by aoflaherty 4/25/2009 1:09:18 PM(UTC)
by MichelleLask 10/29/2008 8:24:25 AM(UTC)
by cwat12 10/6/2008 3:45:19 PM(UTC)
