emethan
#1 Posted : Wednesday, August 11, 2010 6:09:39 PM(UTC)
emethan
Hello
I have Maytag washer. It started with loud clunking noise and when I stopped it I noticed that the sheets were all tangled and wrapped around the agitator. Took everything out and still had that loud noise. On spinning it was working fine. I had repair person to check it out and he said that drive pulley, belt and helix needs to be replaced. I would like to do it on my own, just would like to make sure that is what causing it. And how difficult the job is?Would anyone of you have the same problem? Thanks a lot.
#2 Posted : Thursday, August 12, 2010 3:32:51 AM(UTC)
Here is the parts breakdown
Replacement parts for MAYTAG SAV205DAWW Washer - Top Loading | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/maytag_library/docs/16022937.pdf
See page 30 which should help you decide if you want to tackle this.
Here is a tech bulletin that does sound like your problem.
http://www.servicematters.com/maytag_library/docs/TDL-0104A-B.pdf
emethan
#3 Posted : Thursday, August 12, 2010 7:00:48 AM(UTC)
emethan
Thank you Denman for your help. I will be coming here with more questions as I am trying to fix it myself. Thanks again. Kristyna(emethan)
emethan
#4 Posted : Thursday, August 12, 2010 8:09:15 AM(UTC)
emethan
Silly question
Do I have to totally dissasemble my washer from top to bottom to be able to change the drive pulley,helix and belt?? Kristyna
