Discuss
Kenmore won't spin, but hear motor
 in
Washer Repair
Hello- I just bought a used Kenmore washer, and after lugging it down to the basement, discovered it doesn't work.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore won't spin, but hear motor
  #1 (permalink)
Old 08-27-2008, 08:19 PM
Junior Member
kilbey is on a distinguished road
Default Kenmore won't spin, but hear motor
Model Number: 3953245   Brand: Kenmore   Age: 1 - 5 years
Hello- I just bought a used Kenmore washer, and after lugging it down to the basement, discovered it doesn't work. It fills, and I can hear what sounds like the motor, but no spin or agitation. I read the response from Gene to someone about a broken motor coupling, and wonder if there's a good way to test that visually or by hand.
EDIT:
When I say it won't spin, I don't just mean the spin cycle- I mean it doesn't turn on its own at all.
Any suggestions?
Thanks in advance--
Ads By Google
Related Models
Magic Chef 3962VVA Walloven - S/c Dbl Oven Ele
Magic Chef 3962VVV Walloven - S/c Dbl Oven Ele
Magic Chef 3962XVB Walloven - S/c Dbl Oven Ele
Magic Chef 3968VVA Range - S/c F/s T/svr/booster El
Magic Chef 3968VVV Range - S/c F/s T/svr/booster El
Magic Chef 3968XVB Walloven - S/c Dbl Oven Ele
Whirlpool 3C
Whirlpool 3CA2000XMW0
Whirlpool 3CA2100XMW0
Whirlpool 3CA2100XMW1
Whirlpool 3CA2781XSW0
Whirlpool 3CA2781XSW1
Whirlpool 3CAP2762BN0
Whirlpool 3CAP2762BW0
Whirlpool 3CAP2782BN0
Whirlpool 3CAP2782BW0
Whirlpool 3CDA1100W1
Whirlpool 3CDA1100W2
Whirlpool 3CDA1100W5
Whirlpool 3CDA2000F1
Whirlpool 3CDA2000G0
Whirlpool 3CDA2000W0
Whirlpool 3CDE1700W0
Whirlpool 3CE2110XMW0
Whirlpool 3CE2110XMW1
Whirlpool 3CE2110XMW2
Whirlpool 3CE2910XSN0
Whirlpool 3CE2910XSN1
Whirlpool 3CE2910XSW0
Whirlpool 3CE2910XSW1
Whirlpool 3CEP2910BW0
Whirlpool 3CEP2910DW0
Whirlpool 3CEP2920DW0
Whirlpool 3CEP2950DN0
Whirlpool 3CEP2950DW0
Whirlpool 3CEP2960DN0
Whirlpool 3CEP2960DN2
Whirlpool 3CEP2960DW0
Whirlpool 3CEP2960DW2
Whirlpool 3CFA2000W1
Whirlpool 3CFA2000W3
Whirlpool 3CFA2000W4
Whirlpool 3CFA2000W5
Whirlpool 3CFA2000W6
Whirlpool 3CFCH4AE93
Whirlpool 3CFCH4AS93
Whirlpool 3CFCH4WE93
Whirlpool 3CFCH4WS93
Whirlpool 3CFCHWE93
Whirlpool 3CFCS3AE92
Whirlpool 3CFCS3AS92
Whirlpool 3CFCS3WE92
Whirlpool 3CFCS3WS92
Whirlpool 3CFE2500W0
Whirlpool 3CFE2500W2
Whirlpool 3CFE2510W1
Whirlpool 3CFE2510W2
Whirlpool 3CG2901XSN0
Whirlpool 3CG2901XSN1
Whirlpool 3CG2901XSN3
Whirlpool 3CG2901XSW0
Whirlpool 3CG2901XSW1
Whirlpool 3CG2901XSW3
Whirlpool 3CGP2901DN0
Whirlpool 3CGP2901DW0
Whirlpool 3CGP2901DW1
Whirlpool 3CGP2951BN0
Whirlpool 3CGP2951BW0
Whirlpool 3CGP2951DN0
Whirlpool 3CGP2951DW0
Whirlpool 3CGP2951DW1
Whirlpool 3CSE3A1
Whirlpool 3CSE3W1
Whirlpool 3CSE5A2
Whirlpool 3CSE5W2
Whirlpool 3CSP2760BN0
Whirlpool 3CSP2760BW0
Whirlpool 3CSP2761BN0
Whirlpool 3CSP2761BW0
Whirlpool 3CSP2761BW1
Whirlpool 3CSS3A1
Whirlpool 3CSS3W1
Whirlpool 3CSS5A2
Whirlpool 3CSS5W2
Whirlpool 3CTBE4A
Whirlpool 3CTUE4A
Whirlpool 3DWED5605SQ0 29" Electric Dryer
Whirlpool 3EAC50
Whirlpool 3EAD19SKWR0
Whirlpool 3EAD19XMWR0
Whirlpool 3EAD19XMWR1
Whirlpool 3ECKMF10
Whirlpool 3ECKMF11
Whirlpool 3ECKMF86
Whirlpool 3ECKMF87
Whirlpool 3ECKMF9
Whirlpool 3ED22DQXAN00
Whirlpool 3ED22DQXAW00
Whirlpool 3ED22DQXBN00
Whirlpool 3ED22DQXBN02
Whirlpool 3ED22DQXBN03
Whirlpool 3ED22DQXBW00
Whirlpool 3ED22DQXBW02
Whirlpool 3ED22DQXBW03
Whirlpool 3ED22DQXDN00
Whirlpool 3ED22DQXDN03
Whirlpool 3ED22DQXDW00
Whirlpool 3ED22DQXDW03
Whirlpool 3ED22DWXTN00
Whirlpool 3ED22DWXTN01
Whirlpool 3ED22DWXTW00
Whirlpool 3ED22DWXTW01
Whirlpool 3ED22RQXXW00
Whirlpool 3ED25DQXAN00
Whirlpool 3ED25DQXAW00
Whirlpool 3ED25DQXBN00
Whirlpool 3ED25DQXBN01
Whirlpool 3ED25DQXBW00
Whirlpool 3ED25DQXBW01
Whirlpool 3ED25DQXDN00
  #2 (permalink)
Old 08-27-2008, 08:30 PM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
with a full model number it's easier. But assuming it starts with 110., then yes. You will have to raise the top of the machine, remove the front panel and locate the pump disconnect the electricals to the pump and remove the clips. You can then manuver the pump out of you way to see the coupler between the pump and motor. There are 2 plastic white sections with 3 "legs" and a rubber grommet in the middle, which makes up the coupler. if the legs are broken that's your problem. Cheap easy fix.
Hope that helps,
Nat
  #3 (permalink)
Old 08-27-2008, 08:40 PM
Junior Member
Default
Hi Nat-
Thanks for the quick response. I just checked, and the "legs" seem fine. I can turn the coupling by hand. I also realized that I was looking in the wrong place for the model number. It's 110.20412990.
Any other ideas? Thanks again-
  #4 (permalink)
Old 08-27-2008, 08:54 PM
Senior Expert
APP Volunteer
Default
did you check both white pieces?
  #5 (permalink)
Old 08-27-2008, 08:57 PM
Senior Expert
APP Volunteer
Default
if both look ok then replace the coupler, and pump(making sure clips are good & tight.
Replace the front panel, before you put the top back on locate the wires that connect to the lid switch.
  #6 (permalink)
Old 08-27-2008, 09:03 PM
Senior Expert
APP Volunteer
Default
check to see if the lid switch is cracked or broken....or if you hear it click when raising and lowering the lid or on the connector from the washer use a jumper wire from the white and gray wires(not the green) set the washer on spin(keeping arms legs and other haning objects out of the way of course) if it spins, then you have 2 choices bypass the lid switch or replace it.
  #7 (permalink)
Old 08-27-2008, 09:19 PM
Junior Member
Default
Hi again-
Due to the lateness of the hour, I just leaned the washer forward onto a blanket and looked underneath. I haven't taken anything apart yet. I'm trying to decide whether it's fixable by me, or to return it to the rascal that sold it to me. I paid $80 for it, and it looks in good shape, even underneath.
I also wasn't able to get it to drain when advancing the dial.
Thanks again-
  #8 (permalink)
Old 08-27-2008, 09:30 PM
Senior Expert
APP Volunteer
Default
If I gambled at all, I would say the lid switch and probably the pump need replaced about $50 in parts for a ball park figure.
  #9 (permalink)
Old 08-28-2008, 05:05 AM
Junior Member
Default
Libertyappl-
If I short the lid switch, and that was the problem, it should start turning? And the pump- it could take water in but not drain, if broken?
Thanks again-
  #10 (permalink)
Old 08-28-2008, 06:02 AM
Senior Expert
APP Volunteer
Default
If you use the jumper on the lid switch it should agitate and spin(complete a cycle), if not you may have other issues. If there is an obstruction of the pump is out it won't drain...... If you can determine if it's the lid switch a bypass would be cheaper for you. The pump if it doesn't drain the water out is around $35 part # 3363394.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 10:13 AM
Washer wont do anything but can hear motor ronandtracey@charter.net Dishwasher Repair 1 12-06-2009 07:12 PM
Motor won't spin Glen@151 Dryer Repair 3 06-26-2009 10:49 AM
washer doesnt spin all i hear is buzzing and the smell of smoke willp3 Washer Repair 8 06-23-2009 01:45 AM
Motor won't Spin sarrigo Washer Repair 1 02-27-2008 05:06 PM
