when finished filling with water during agitation water goes out flood tube pressure/fill switch has been changed but problem continues....any ideas?
Thanks!
On this model there was a problem with the brake bearings. At one time you could change the brake bearings but they don’t sell the bearing kit anymore. Now you have to change the transmission. When the brake was bad the spin basket would spin in one direction during the wash cycle. When this happens water will be forced over the tub into the floor. Take the front off and watch it during wash if the spin basket spins during wash the transmission will have to be replaced. However if the washer is overflowing (filling too high) and you already changed the water level control check to see if the tube that connects to the control is partially clogged. GE Washer Disassembly Guide Should you replace the transmission this page should help.
basket is spinning no obstruction in hoses guess I'll be checking on the price of transmission! Thanks for the quick response!
