Major leak at front, center bottom of washer when tub is filling. Washer is about 10 years old. Best to replace or spend the $127 just to have the serviceman show up?
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
A model number would help, but I'll take a guess. If its a standard top loader, then the leak is probably the water pump. You should be able to replace it yourself in less than 1/2 an hour. Pumps cost less than $50.
Post an model no. and I'll try and provide a part number and instructions.
