Discuss
F1 code
 in
Washer Repair
My washer will stop working an show an f1 code. What is this code? We have to push stop and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » F1 code
  #1 (permalink)
Old 08-27-2008, 03:15 PM
Junior Member
albertdiaz is on a distinguished road
Default F1 code
Model Number: 11027062603   Brand: Kenmore   Age: 1 - 5 years
My washer will stop working an show an f1 code. What is this code? We have to push stop and start bottons before it will start working. Would like to know if a part is going-out so I can have it replaced.
Ads By Google
Related Models
Kenmore 11027062603 RESIDENTIAL WASHER
Kenmore 11027062604 RESIDENTIAL WASHER
Kenmore 11027072600 WASHER
Kenmore 11027072601 RESIDENTIAL WASHER
Kenmore 11027072602 RESIDENTIAL WASHER
Kenmore 11027072603 RESIDENTIAL WASHER
Kenmore 11027072604 RESIDENTIAL WASHER
Kenmore 11027082600 RESIDENTIAL WASHER
Kenmore 11027082601 RESIDENTIAL WASHER
Kenmore 11027082602 RESIDENTIAL WASHER
Kenmore 11027082603 WASHER
Kenmore 11027082604 RESIDENTIAL WASHER
Kenmore 11027082605 RESIDENTIAL WASHER
Kenmore 11027086601 RESIDENTIAL WASHER
Kenmore 11027086602 RESIDENTIAL WASHER
Kenmore 11027086603 RESIDENTIAL WASHER
Kenmore 11027086604 RESIDENTIAL WASHER
Kenmore 11027086605 RESIDENTIAL WASHER
Kenmore 11027087600 RESIDENTIAL WASHER
Kenmore 11027087601 RESIDENTIAL WASHER
Kenmore 11027087602 RESIDENTIAL WASHER
Kenmore 11027087603 RESIDENTIAL WASHER
Kenmore 11027087604 RESIDENTIAL WASHER
Kenmore 11027087605 RESIDENTIAL WASHER
Kenmore 11027092600 WASHER
Kenmore 11027092601 RESIDENTIAL WASHER
Kenmore 11027092602 RESIDENTIAL WASHER
Kenmore 11027092603 RESIDENTIAL WASHER
Kenmore 11027112600 WASHER
Kenmore 11027152600 AUTOMATIC WASHER
Kenmore 11027152601 RESIDENTIAL WASHER
Kenmore 11027152602 RESIDENTIAL WASHER
Kenmore 11027172600 WASHER
Kenmore 11027222600 RESIDENTIAL WASHERS
Kenmore 11027224600 RESIDENTIAL WASHERS
Kenmore 11027272600 WASHER
Kenmore 11027322600 RESIDENTIAL WASHERS
Kenmore 11027332600 RESIDENTIAL WASHERS
Kenmore 11027342600 RESIDENTIAL WASHERS
Kenmore 11027422600 RESIDENTIAL WASHERS
Kenmore 11027432600 RESIDENTIAL WASHERS
Kenmore 11027442600 RESIDENTIAL WASHER
Kenmore 11027522600 RESIDENTIAL WASHERS
Kenmore 11027532600 RESIDENTIAL WASHERS
Kenmore 11027542600 RESIDENTIAL WASHER
Kenmore 11027612600 RESIDENTIAL WASHERS
Kenmore 11027622790 AUTOMATIC WASHER
Kenmore 11027622791 AUTOMATIC WASHER
Kenmore 11027632600 RESIDENTIAL WASHERS
Kenmore 11027642600 RESIDENTIAL WASHERS
Kenmore 11027721600 RESIDENTIAL WASHER
Kenmore 11027731600 RESIDENTIAL WASHERS
Kenmore 11027741600 RESIDENTIAL WASHERS
Kenmore 11027751700 RESIDENTIAL WASHER
Kenmore 11027761700 RESIDENTIAL WASHER
Kenmore 11027782700 RESIDENTIAL WASHER
Kenmore 11027802690 AUTOMATIC WASHER
Kenmore 11027802691 AUTOMATIC WASHER
Kenmore 11027812690 AUTOMATIC WASHER
Kenmore 11027812691 AUTOMATIC WASHER
Kenmore 11027812692 AUTOMATIC WASHER
Kenmore 11027822790 AUTOMATIC WASHER
Kenmore 11027824790 AUTOMATIC WASHER
Kenmore 11027831600 RESIDENTIAL WASHER
Kenmore 11027841600 RESIDENTIAL WASHERS
Kenmore 11027852790 AUTOMATIC WASHER
Kenmore 11027852791 AUTOMATIC WASHER
Kenmore 11027862790 AUTOMATIC WASHER
Kenmore 11027871600 RESIDENTIAL WASHERS
Kenmore 11027872600 RESIDENTIAL WASHERS
Kenmore 11027874600 RESIDENTIAL WASHERS
Kenmore 11027892790 AUTOMATIC WASHER
Kenmore 11027892791 AUTOMATIC WASHER
Kenmore 11027894790 AUTOMATIC WASHER
Kenmore 11027894791 AUTOMATIC WASHER
Kenmore 11027902790 AUTOMATIC WASHER
Kenmore 11027982790 AUTOMATIC WASHER
Kenmore 11028002010 AUTOMATIC WASHER
Kenmore 11028002011 AUTOMATIC WASHER
Kenmore 11028012010 AUTOMATIC WASHER
Kenmore 11028012011 AUTOMATIC WASHER
Kenmore 11028032700 RESIDENTIAL WASHER
Kenmore 11028032701 RESIDENTIAL WASHER
Kenmore 11028042700 RESIDENTIAL WASHER
Kenmore 11028042701 WASHER
Kenmore 11028062800 RESIDENTIAL WASHER
Kenmore 11028072800 RESIDENTIAL WASHER
Kenmore 11028081700 WASHER
Kenmore 11028082700 RESIDENTIAL WASHER
Kenmore 11028087700 RESIDENTIAL WASHER
Kenmore 11028091700 WASHER
Kenmore 11028092700 RESIDENTIAL WASHER
Kenmore 11028097700 WASHER
Kenmore 11028222700 RESIDENTIAL WASHER
Kenmore 11028222701 WASHER
Kenmore 11028299890 AUTOMATIC WASHER
Kenmore 11028322700 RESIDENTIAL WASHER
Kenmore 11028332700 RESIDENTIAL WASHER
Kenmore 11028352700 RESIDENTIAL WASHER
Kenmore 11028362700 RESIDENTIAL WASHER
Kenmore 11028372700 RESIDENTIAL WASHER
Kenmore 11028422700 RESIDENTIAL WASHER
Kenmore 11028432700 RESIDENTIAL WASHER
Kenmore 11028522700 RESIDENTIAL WASHER
Kenmore 11028522701 RESIDENTIAL WASHER
Kenmore 11028532700 RESIDENTIAL WASHER
Kenmore 11028532701 RESIDENTIAL WASHER
Kenmore 11028622700 RESIDENTIAL WASHER
Kenmore 11028622701 RESIDENTIAL WASHER
Kenmore 11028632700 RESIDENTIAL WASHER
Kenmore 11028632701 RESIDENTIAL WASHER
Kenmore 11028692700 RESIDENTIAL WASHER
Kenmore 11028692701 RESIDENTIAL WASHER
Kenmore 1102870090 AUTOMATIC WASHER
Kenmore 11028722700 RESIDENTIAL WASHER
Kenmore 11028732700 RESIDENTIAL WASHER
Kenmore 11028752700 RESIDENTIAL WASHER
Kenmore 11028762700 RESIDENTIAL WASHER
Kenmore 11028782700 RESIDENTIAL WASHER
Kenmore 11028802890 AUTOMATIC WASHER
  #2 (permalink)
Old 08-27-2008, 07:11 PM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
This is what Whirlpool (which is who makes the 110 series) says about a F1 code:
F
then 1 flashes when the control detects an
out of range pressure signal.
Check pressure hose connection from tub
to machine/motor control. Is hose pinched
or kinked?
If F then 1 repeats numerous times after
POWER is pressed and the pressure hose
connection is not pinched or kinked,
replace the machine/motor control.
Hope that helps
Nat
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
code ld dllee021 Washer Repair 3 04-10-2013 07:12 PM
F 1 code sjb Oven Repair (including Ranges and Cooktops) 0 11-29-2009 03:35 PM
code pf ej45 Dishwasher Repair 3 08-20-2009 12:23 PM
need code asap24 Dishwasher Repair 1 04-21-2008 03:07 PM
need a code# frankvalencia Heating, Ventilation, and Air Conditioning (HVAC) 0 04-21-2008 10:03 AM
