Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   F1 code (http://forum.appliancepartspros.com/washer-repair/11355-f1-code.html)
albertdiaz 08-27-2008 03:15 PM
F1 code
My washer will stop working an show an f1 code. What is this code? We have to push stop and start bottons before it will start working. Would like to know if a part is going-out so I can have it replaced.
libertyappl 08-27-2008 07:11 PM
This is what Whirlpool (which is who makes the 110 series) says about a F1 code:
F
then 1 flashes when the control detects an
out of range pressure signal.
Check pressure hose connection from tub
to machine/motor control. Is hose pinched
or kinked?
If F then 1 repeats numerous times after
POWER is pressed and the pressure hose
connection is not pinched or kinked,
replace the machine/motor control.
Hope that helps
Nat
