Discuss
GE Top Loader does everything but agitate (well it's agitating me!)
 in
Washer Repair
My top loading GE Washer seems to do everything except agitate. I've made appliance repairs (actually just on my
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Top Loader does everything but agitate (well it's agitating me!)
  #1 (permalink)
Old 08-26-2008, 08:15 PM
rockstar_not rockstar_not is offline
Junior Member
rockstar_not is on a distinguished road
Default GE Top Loader does everything but agitate (well it's agitating me!)
Model Number: WJSR2080V1WW   Brand: GE   Age: 5 - 10 years
My top loading GE Washer seems to do everything except agitate. I've made appliance repairs (actually just on my old Maytag gas dryer) and I think I'm up to the task if it's a fairly simple thing.
Is there a way to remove the Agitator - I've seen some posts on other models that say to just pull up sharply on the Agitator.
I've seen another post that says this might be a pretty cheap repair - some kind of torque overload protector that fails intentionally.
Agitator top part spins one direction like it's clutched somehow. The bottom of the agitator assembly (the part that just has the 4 vertical flutes on it, not the corkscrewed flutes) spins freely in both clockwise and counter-clockwise directions.
Any clues on what might be wrong here and how to get started repairing? Family of 6 has laundry piling up.
-Scott
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-26-2008, 08:30 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
By looking at the breakdown it looks like remove the fabric softener and look down there appears to be a bolt, if so after you remove that you should just be able to pull straight up and there is an agitator coupler uner there that may be you problem.
Hope that helps,
Nat
  #3 (permalink)
Old 08-26-2008, 08:40 PM
Junior Member
Default
Well, I went for it and yanked up on the Agitator - seems fine. There was a 7/16 nut, cranked it open, and the 'air bell' plastic teeth that fit on the spline were basically ground down to nothingness.
I'll assume that's where my problem is. Looks like a fairly inexpensive part to replace if I can find one locally.
  #4 (permalink)
Old 08-26-2008, 08:44 PM
Senior Expert
APP Volunteer
Default
That sure sounds ike the problem, the part number is WH43X0137
Hope that gets you up and going. Although unless there's a GE repiar place or a main parts supplier that's probably not a part most local shop would have in stock. Or at least we don't, of course there's not many GE's around here.
  #5 (permalink)
Old 08-26-2008, 08:45 PM
Senior Expert
APP Volunteer
Default
Part from here is less than $5 part number AP3964635
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag not agitating sds5150 Washer Repair 3 06-28-2008 04:34 AM
2-yr-old Estate top not agitating quizcook Washer Repair 4 12-18-2007 02:06 PM
Tub Spins While Agitating icoetmartyp Washer Repair 0 12-07-2007 11:42 PM
not agitating Joanna Washer Repair 1 11-29-2007 02:36 PM
Washer not agitating Todd Washer Repair 1 09-18-2007 02:45 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
