Discuss
washer won't fill
 in
Washer Repair
Washer won't fill with cold water. Hot is fine. If you switch the hoses just the opposite is true.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer won't fill
  #1 (permalink)
Old 08-26-2008, 05:03 PM
richrds2 richrds2 is offline
Junior Member
richrds2 is on a distinguished road
Default washer won't fill
Model Number: 110.82673110   Brand: Whirlpool   Age: 5 - 10 years
Washer won't fill with cold water. Hot is fine. If you switch the hoses just the opposite is true. My question is " Should I replace the water inlet valve and if so, can I use a universal one?" Thanks in advance
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-26-2008, 05:09 PM
abadfish66's Avatar
abadfish66 abadfish66 is online now
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
First I would take the hose off the valve and inspect the screen on the valve, and the screens on the hose if any for a clog.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 08-26-2008, 07:38 PM
Junior Member
Default
I did that already and water to machine was fine. I suspect either the valve is defective or there is no power to one side. I'm just not sure where to go from here
  #4 (permalink)
Old 08-26-2008, 08:40 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
If I may throw in my 2 cents.....it sounds like the valve is out
Nat
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will only Fill sailfastnu Washer Repair 2 08-14-2008 06:37 AM
Washer will fill only, but will not run. spectra57 Washer Repair 5 08-09-2008 05:00 AM
washer will fill but won't run tltakj Washer Repair 1 06-17-2008 04:49 AM
Washer will not fill johnkh1949 Washer Repair 0 06-16-2008 11:08 AM
washer won't fill up all the way countrygirl2 Washer Repair 0 02-13-2008 01:38 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
