| » How do you test if pump is bad? |
Model Number: KAWS750JQ2 Brand: Kitchen Aid Age: 5 - 10 years
Our washer stalled after it filled with water -- I could go back and start the wash cycle over and it did agitate. I drained it by hand by lowering the hose into a bucket on the floor (not plugged) -- checked the lid switch, and the screw holders have crumbled -- so I will replace this. But -- I after switching it on by hand -- the water would not drain. Is there anything else I can check before ordering a new pump. -- thanks
Before I disassembled it: if I put the dial in drain mode -- no sounds -- no agitation -- nothing. After I hand drained the basket-- it would spin in spin mode (although clunky). Is there an additional way that I need to test this?
| Display Modes | |
| Dryer finishes cycle but clothers damp - Test moisture sensor ? | rkpatt | Dryer Repair | 5 | 09-17-2007 10:08 AM |
| Drain Pump | loadster | Dishwasher Repair | 1 | 08-07-2007 07:35 PM |
| Replacing Pump | pdiddy | Washer Repair | 0 | 07-23-2007 01:43 AM |
| Changing Pump | pdiddy | Washer Repair | 1 | 07-20-2007 07:05 PM |
