Discuss
Maytag Neptune front load 3E error during spin
 in
Washer Repair
I am getting a 3E code during the spin cycle. I checked all wire connections, ran a Quick Spin Test,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Neptune front load 3E error during spin
  #1 (permalink)
Old 08-09-2010, 08:44 AM
Junior Member
garrowg is on a distinguished road
Default Maytag Neptune front load 3E error during spin
Model Number: MAH8700AWW   Brand: Maytag   Age: 1 - 5 years
I am getting a 3E code during the spin cycle. I checked all wire connections, ran a Quick Spin Test, washer will get up to about 150 then 3E. I am getting less than 3 ohms from the 1,2,& 3 pins at the motor, but using a little analog meter. I don't want to chase this problem or throw parts at it. My question, should I replace the control board or the motor?
Ads By Google
Related Models
Maytag MAH8700AWW Washer - Horizontal Axis
Maytag MAH9700AWM Washer - Horizontal Axis
Maytag MAH9700AWQ Washer - Horizontal Axis
Maytag MAH9700AWW Washer - Horizontal Axis
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM Misc / Accessory
Maytag MAL1800AXQ Misc / Accessory
Maytag MAL1800AXW Misc / Accessory
Maytag MAL2000AXQ Misc / Accessory
Maytag MAL2000AXW Misc / Accessory
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL Washer - Top Loading
Maytag MAT10CSAAW Washer - Top Loading
Maytag MAT10CSAGL Washer - Top Loading
Maytag MAT10CSAGW Washer - Top Loading
Maytag MAT10CSBKL Washer - Top Loading
Maytag MAT10CSEGL Washer - Top Loading
Maytag MAT10CSEGW Washer - Top Loading
Maytag MAT10DAAAL Washer - Top Loading
Maytag MAT10DAAAW Washer - Top Loading
Maytag MAT10DAABL Washer - Top Loading
Maytag MAT10DAABW Washer - Top Loading
Maytag MAT10PDAAL Washer - Top Loading
Maytag MAT10PDAAW Washer - Top Loading
Maytag MAT10PDABL Washer - Top Loading
Maytag MAT10PDABW Washer - Top Loading
Maytag MAT10PDEGW Washer - Top Loading
Maytag MAT10PSAAL Washer - Top Loading
Maytag MAT10PSAAW Washer - Top Loading
Maytag MAT10PSAGL Washer - Top Loading
Maytag MAT10PSAGW Washer - Top Loading
Maytag MAT11CSBKL Washer - Top Loading
Maytag MAT11MNAAW Washer - Top Loading
Maytag MAT11MNAGW Washer - Top Loading
Maytag MAT11MNEGW Washer - Top Loading
Maytag MAT11PDAAL Washer - Top Loading
Maytag MAT11PDAAW Washer - Top Loading
Maytag MAT11PDABL Washer - Top Loading
Maytag MAT11PDABW Washer - Top Loading
Maytag MAT12CSAAL Washer - Top Loading
Maytag MAT12CSAAQ Washer - Top Loading
Maytag MAT12CSAAW Washer - Top Loading
Maytag MAT12CSAGW Washer - Top Loading
Maytag MAT12CSAKL Washer - Top Loading
Maytag MAT12CSAKQ Washer - Top Loading
Maytag MAT12CSDAQ Washer - Top Loading
Maytag MAT12CSDAW Washer - Top Loading
Maytag MAT12CSDGW Washer - Top Loading
Maytag MAT12CSEGW Washer - Top Loading
Maytag MAT12CSFWQ Washer - Top Loading
Maytag MAT12CSFWW Washer - Top Loading
Maytag MAT12PDAAL Washer - Top Loading
Maytag MAT12PDAAW Washer - Top Loading
Maytag MAT12PDABL Washer - Top Loading
Maytag MAT12PDABW Washer - Top Loading
Maytag MAT12PDAGW Washer - Top Loading
Maytag MAT12PDBAL Washer - Top Loading
Maytag MAT12PDBAQ Washer - Top Loading
Maytag MAT12PDBAW Washer - Top Loading
Maytag MAT12PDBBL Washer - Top Loading
Maytag MAT12PDBBQ Washer - Top Loading
Maytag MAT12PDBBW Washer - Top Loading
Maytag MAT12PDCBL Washer - Top Loading
Maytag MAT12PDCBQ Washer - Top Loading
Maytag MAT12PDCBW Washer - Top Loading
Maytag MAT12PDDAQ Washer - Top Loading
Maytag MAT12PDDAW Washer - Top Loading
Maytag MAT12PDDBW Washer - Top Loading
Maytag MAT12PDDGW Washer - Top Loading
Maytag MAT12PDEGW Washer - Top Loading
Maytag MAT12PDLAQ Washer - Top Loading
Maytag MAT12PDLAW Washer - Top Loading
Maytag MAT12PDLGW Washer - Top Loading
Maytag MAT12PDSAW Washer - Top Loading
Maytag MAT12PRAAW Washer - Top Loading
Maytag MAT12PRAEW Washer - Top Loading
Maytag MAT12PRBAW Washer - Top Loading
Maytag MAT12PRDAW Washer - Top Loading
Maytag MAT12PRSAW Washer - Top Loading
Maytag MAT12PSAAW Washer - Top Loading
Maytag MAT12PSAGW Washer - Top Loading
Maytag MAT12PSBAW Washer - Top Loading
Maytag MAT12PSDAW Washer - Top Loading
Maytag MAT12PSLWQ Washer - Top Loading
Maytag MAT12PSLWW Washer - Top Loading
Maytag MAT13MNAAW Washer - Top Loading
Maytag MAT13MNAGW Washer - Top Loading
Maytag MAT13MNDAW Washer - Top Loading
Maytag MAT13MNDGW Washer - Top Loading
Maytag MAT13MNEGW Washer - Top Loading
Maytag MAT13PDAAW Washer - Top Loading
Maytag MAT13PDBAW Washer - Top Loading
Maytag MAT13PNAEW Washer - Top Loading
Maytag MAT13PNDEW Washer - Top Loading
Maytag MAT13PRBWW Washer - Top Loading
Maytag MAT230CAAG Washer - Top Loading
Maytag MAT23PCAAC Washer - Top Loading
Maytag MAT23PCAAG Washer - Top Loading
Maytag MAT23PCAAL Washer - Top Loading
Maytag MAT23PCAAW Washer - Top Loading
Maytag MAT23PCABG Washer - Top Loading
Maytag MAT23PCABL Washer - Top Loading
Maytag MAT23PCABW Washer - Top Loading
Maytag MAT25CSAAG Washer - Top Loading
Maytag MAT25CSAAL Washer - Top Loading
Maytag MAT25CSAAW Washer - Top Loading
Maytag MAT25CSAGG Washer - Top Loading
Maytag MAT25CSAGL Washer - Top Loading
Maytag MAT25CSAGW Washer - Top Loading
Maytag MAT25CSBIL Washer - Top Loading
Maytag MAT25CSCAG Washer - Top Loading
Maytag MAT25CSCAL Washer - Top Loading
Maytag MAT25CSCAW Washer - Top Loading
Maytag MAT25CSEGG Washer - Top Loading
Maytag MAT25CSEGL Washer - Top Loading
Maytag MAT25CSEGW Washer - Top Loading
Maytag MAT25CTAAG Washer - Top Loading
Maytag MAT25CTAAL Washer - Top Loading
Maytag MAT25CTAAW Washer - Top Loading
Maytag MAT25DAAAL Washer - Top Loading
  #2 (permalink)
Old 08-09-2010, 12:20 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Your motor winding(s) test are correct and in range.
Check for the same resistance readings at the CN9 connector(large red, white and blue wires).
That will tell you that both the wiring and the motor windings are proper,and you will need to replace the main control board,or you have a loose connection or damaged wire in the harness to the motor.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-16-2010, 08:27 PM
Junior Member
Default
Joe, I was able to get a good meter, retested the resistance at the motor and at CN9. At pin 1 and 2 (Blue and White) reads 1.4ohms. At pin 1 and 3 (Blue and Red) reads 2.4ohms, and at 2 and 3 (White and Red) reads 2.4ohms. I get the same readings at CN9. What do you think now? The resistance is the same at the motor and the board but they are lower than posted in the Tech Manual which should be 3ohms. I don't want to replace the board at $250 and find out that it is the motor and have to spend another $250.
  #4 (permalink)
Old 08-17-2010, 08:05 AM
Senior Expert
Default
I'm still not too worried about your motor resistances at present.
All your tests show resistances within the allowable tolerances(+/- 10%)
except the 1.4 ohms.(I'm still not too worried though).
I need to get another resistance reading check for you, and will need to wait until the tech team gets back to me.(later today/ tomorrow).
I'll be more comfortable after the next test.
Get back to you as soon as I can.
__________________
Joe M. APP TEAM
  #5 (permalink)
Old 08-19-2010, 08:11 AM
Senior Expert
Default
Sorry for the delay,
I want you to check the motor (hall) sensor circuits at the CN8 connector at the main control board(Has a blue#3, orange#4, and pink#1 wires).
Across the Blue and Pink wires in the connector you should read 4.7 ohms resistance(+/- 10%).
From the Orange#4 wire to Blue#3 and Orange#4 to Pink#1 wires, you should read infinte resistance.
With the tests you made previously, and this test(CN8) :
If you have the proper resistance readings(CN8) , Replace the control board.
If you do not have the proper resistance readings(CN8) , replace the motor.
That ought to get you properly diagnosed and repaired.
GOOD LUCK.
__________________
Joe M. APP TEAM
  #6 (permalink)
Old 08-19-2010, 09:31 AM
Junior Member
Default
Ok, I tested at the CN8 connector. Blue#3 and Pink#1 reads 4.7k ohms.
Orange#4 and Pink#1 reads 20.59M ohms, Orange#4 and Blue#3 reads 20.59M ohms. So...not sure if those are the proper readings, but I did some more testing. I ran the Quick Spin test, on about the 4th step/cycle I pressed the Rotary Selector to hold the spin at about 165. I let it run for about a minute or less. I could smell something getting hot and noticed what appeared to be smoke coming from the motor. The motor was very hot to touch. I know someone that has the same model washer and will borrow the control board for a test. Will let you know the results.
  #7 (permalink)
Old 08-19-2010, 09:42 AM
Senior Expert
Default
OK,
Would appreciate an update.
Right now, it looks like you need a motor.
__________________
Joe M. APP TEAM
  #8 (permalink)
Old 08-23-2010, 03:52 PM
Junior Member
Default
You are correct sir....it was the motor. Sorry it took so long to post this, but the first motor I got was broken out of the box. One of the mounts on the housing and the wire connector was broke, probably during shipping. I called it in and a new one was sent Friday and received today. I tested before mounting and got 2.4 and 2.5 ohms across pins 1,2,& 3. I installed, tested at CN8, got the same readings, ran the Quick Spin test, cranked up like it was supposed to, display was reading 1073. After the QS test, I ran a Quick Service test...everything passed. Just FYI to all the readers, I re-leveled the machine before starting it up...never hurts to check the small things. Thanks for your help.
  #9 (permalink)
Old 08-24-2010, 07:50 AM
Senior Expert
Default
You're very welcome,
Thanks, for letting us know.
Glad to hear you're up and running.
__________________
Joe M. APP TEAM
  #10 (permalink)
Old 01-11-2011, 06:41 AM
Junior Member
krokadial is on a distinguished road
Default Control Panel
How do we take off the front panel to access the control panel?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune Front load washer mnunno Washer Repair 8 05-09-2012 03:40 PM
MAYTAG NEPTUNE FRONT LOAD WASHER, Clothes come out soaking wet debbielf Washer Repair 3 09-01-2009 05:13 AM
Maytag Neptune Front Load Washer Help debster101 Washer Repair 1 07-24-2009 10:31 AM
Maytag neptune front load shakes yappy Washer Repair 0 03-20-2009 08:01 AM
Maytag Neptune front load Washer castillocm Dryer Repair 1 07-31-2008 06:36 PM
