Discuss
Whirlpool Duet Drains Back into Drum
 in
Washer Repair
Our Whirlpool Duet washer will fully drain, but after the cycle is complete, water will start to appear in the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Duet Drains Back into Drum
  #1 (permalink)
Old 08-24-2008, 07:04 PM
Geetch Geetch is offline
Junior Member
Geetch is on a distinguished road
Default Whirlpool Duet Drains Back into Drum
Model Number: GHW9100LW2   Brand: Whirlpool   Age: 1 - 5 years
Our Whirlpool Duet washer will fully drain, but after the cycle is complete, water will start to appear in the bottom of the tub. If the clothes are still in the tub, they will of course absorb the water causing them to smell.
The pump seems to work fine. It pumps all of the water out, but then after a while water will flow back into the tub.
I have cleaned out the drain filter which didn't help. I suspected that the water that remains in the drain hose was somehow able to flow back into the tub. I thought that maybe the hose between the tub and pump which has that ball in it might be to blame. I removed it and cleaned it thoroughly thinking that maybe the ball was dirty and not allowing for a tight seal to prevent water from backing up into the tub.
I thought I had the problem solved, but it's back. Could it be the pump even though it pumps all of the water out? Does the pump also prevent water from flowing back into the tub? If it's not the ball thingy (eco-valve?) or the pump---then what could it possibly be?
Thanks in advance for your help!
Related Models
Whirlpool GHW9100LW2 Automatic Washer
Whirlpool GHW9150PW0 Automatic Washer
Whirlpool GHW9150PW1 Automatic Washer
Whirlpool GHW9150PW2 Automatic Washer
Whirlpool GHW9150PW3 Automatic Washer
Whirlpool GHW9150PW4 Automatic Washer
Whirlpool GHW9160PW0 Automatic Washer
Whirlpool GHW9160PW1 Automatic Washer
Whirlpool GHW9160PW2 Automatic Washer
Whirlpool GHW9160PW3 Automatic Washer
Whirlpool GHW9160PW4 Automatic Washer
Whirlpool GHW9200LQ0
Whirlpool GHW9200LW0
Whirlpool GHW9250ML0 Automatic Washer
Whirlpool GHW9250ML1 Automatic Washer
Whirlpool GHW9250ML2 Automatic Washer
Whirlpool GHW9250MQ0 Automatic Washer
Whirlpool GHW9250MQ1 Automatic Washer
Whirlpool GHW9250MQ2 Automatic Washer
Whirlpool GHW9250MT0 Automatic Washer
Whirlpool GHW9250MT1 Automatic Washer
Whirlpool GHW9250MT2 Automatic Washer
Whirlpool GHW9250MW0 Automatic Washer
Whirlpool GHW9250MW1 Automatic Washer
Whirlpool GHW9250MW2 Automatic Washer
Whirlpool GHW9300PW0 Automatic Washer
Whirlpool GHW9300PW1 Automatic Washer
Whirlpool GHW9300PW2 Automatic Washer
Whirlpool GHW9300PW3 Automatic Washer
Whirlpool GHW9300PW4 Automatic Washer
Whirlpool GHW9400PL0 Automatic Washer
Whirlpool GHW9400PL1 Automatic Washer
Whirlpool GHW9400PL2 Automatic Washer
Whirlpool GHW9400PL3 Automatic Washer
Whirlpool GHW9400PL4 Automatic Washer
Whirlpool GHW9400PT0 Automatic Washer
Whirlpool GHW9400PT1 Automatic Washer
Whirlpool GHW9400PT2 Automatic Washer
Whirlpool GHW9400PT3 Automatic Washer
Whirlpool GHW9400PT4 Automatic Washer
Whirlpool GHW9400PW0 Automatic Washer
Whirlpool GHW9400PW1 Automatic Washer
Whirlpool GHW9400PW2 Automatic Washer
Whirlpool GHW9400PW3 Automatic Washer
Whirlpool GHW9400PW4 Automatic Washer
Whirlpool GHW9400SU0 Automatic Washer
Whirlpool GHW9460PL0 Automatic Washer
Whirlpool GHW9460PL1 Automatic Washer
Whirlpool GHW9460PL2 Automatic Washer
Whirlpool GHW9460PL3 Automatic Washer
Whirlpool GHW9460PL4 Automatic Washer
Whirlpool GHW9460PW0 Automatic Washer
Whirlpool GHW9460PW1 Automatic Washer
Whirlpool GHW9460PW2 Automatic Washer
Whirlpool GHW9460PW3 Automatic Washer
Whirlpool GHW9460PW4 Automatic Washer
Whirlpool GHWT160JXX0
Whirlpool GI1500PHB0
Whirlpool GI1500PHB3
Whirlpool GI1500PHB4 Ice Cube Maker
Whirlpool GI1500PHB5 Ice Cube Maker
Whirlpool GI1500PHB6 Ice Cube Maker
Whirlpool GI1500PHB7 Ice Cube Maker
Whirlpool GI1500PHB8 Ice Cube Maker
Whirlpool GI1500PHW0
Whirlpool GI1500PHW3
Whirlpool GI1500PHW4 Ice Cube Maker
Whirlpool GI1500PHW5 Ice Cube Maker
Whirlpool GI1500PHW6 Ice Cube Maker
Whirlpool GI1500PHW7 Ice Cube Maker
Whirlpool GI1500PHW8 Ice Cube Maker
Whirlpool GI1500XHB0
Whirlpool GI1500XHB1
Whirlpool GI1500XHB2
Whirlpool GI1500XHB3
Whirlpool GI1500XHB4 Ice Cube Maker
Whirlpool GI1500XHB5 Ice Cube Maker
Whirlpool GI1500XHB6 Ice Cube Maker
Whirlpool GI1500XHB7 Ice Cube Maker
Whirlpool GI1500XHB8 Ice Cube Maker
Whirlpool GI1500XHB9 Ice Cube Maker
Whirlpool GI1500XHN0
Whirlpool GI1500XHN1
Whirlpool GI1500XHN2
Whirlpool GI1500XHN3
Whirlpool GI1500XHN4 Ice Cube Maker
Whirlpool GI1500XHS0
Whirlpool GI1500XHS1
Whirlpool GI1500XHS2
Whirlpool GI1500XHS3
Whirlpool GI1500XHS4 Ice Cube Maker
Whirlpool GI1500XHS5 Ice Cube Maker
Whirlpool GI1500XHS6 Ice Cube Maker
Whirlpool GI1500XHS7 Ice Cube Maker
Whirlpool GI1500XHS8 Ice Cube Maker
Whirlpool GI1500XHS9 Ice Cube Maker
Whirlpool GI1500XHT1
Whirlpool GI1500XHT2
Whirlpool GI1500XHT3
Whirlpool GI1500XHT4 Ice Cube Maker
Whirlpool GI1500XHT5 Ice Cube Maker
Whirlpool GI1500XHT6 Ice Cube Maker
Whirlpool GI1500XHT7 Ice Cube Maker
Whirlpool GI1500XHT8 Ice Cube Maker
Whirlpool GI1500XHT9 Ice Cube Maker
Whirlpool GI1500XHW0
Whirlpool GI1500XHW1
Whirlpool GI1500XHW2
Whirlpool GI1500XHW3
Whirlpool GI1500XHW4 Ice Cube Maker
Whirlpool GI1500XHW5 Ice Cube Maker
Whirlpool GI1500XHW6 Ice Cube Maker
Whirlpool GI1500XHW7 Ice Cube Maker
Whirlpool GI1500XHW8 Ice Cube Maker
Whirlpool GI1500XHW9 Ice Cube Maker
Whirlpool GI15NDXTB0 Ice Cube Maker
Whirlpool GI15NDXTB1 Ice Cube Maker
Whirlpool GI15NDXTQ0 Ice Cube Maker
Whirlpool GI15NDXTQ1 Ice Cube Maker
Whirlpool GI15NDXTQO Ice Cube Maker
  #2 (permalink)
Old 08-24-2008, 07:54 PM
jdappl07 jdappl07 is offline
Senior Expert
APP Volunteer
jdappl07 is on a distinguished road
Default
check and see if drain hose is down in the drain to far should only be down 6 inchs as long as it isn't passed the pee trap
__________________
J&D Appliance Repair Serving Pendleton County, Kentucky and Surrounding Areas
  #3 (permalink)
Old 08-24-2008, 08:31 PM
Junior Member
Default
The drain hose is not down too far. It is the type with the hook that won't let it go down too far. I'm sure that the water is not siphoning back from the drain pipe. It is flowing back from the washer drain hose. It's always the same volume of water--the amount that is left in the hose that can't make it up to the drain pipe after the pump shuts off. Rather than just staying in the hose until the next drain cycle, it slowly seeps back through the pump and up into the drum.
  #4 (permalink)
Old 08-24-2008, 08:40 PM
Senior Expert
APP Volunteer
Default
take the bottom panel off and drain the drain pump in to a pan check the catch all for gunk build up. If it isn't that or the drain pipe the only other place water can come from is the water valve
__________________
  #5 (permalink)
Old 09-04-2008, 11:42 AM
jholmes jholmes is offline
Junior Member
jholmes is on a distinguished road
Default This is an EASY fix
Please see this article (with pictures) that will tell you how to fix the inlet water valve and stop the problem.
Need to buy the part (# is provided) and then replace.
Out.
Water in leaking into tub overnight - FixYa
  #6 (permalink)
Old 09-23-2008, 07:16 PM
Junior Member
Default
Out.
Thanks jholmes! This indeed appears to have been the problem. I can't completely confirm that this solved it yet, but I bought the new inlet valve and just installed it. I then tested the old valve out of the machine by putting the water line back on and turning on the water. I tested both sides. The hot water side did not leak, but the cold water valve leaked--so I'm confident that this was the problem. Thanks again!
Edited to add that after several weeks of use I can now confirm that this fixed the problem!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet F32 RCM78 Washer Repair 4 06-01-2008 04:27 PM
whirlpool direct drive washer drains, but no spin antennaejim Washer Repair 5 02-24-2008 04:25 PM
Drier drum belt how to start in the back or front??? White westinghouse Dryer Repair 2 12-05-2007 03:37 PM
bad drum felt seal(s) Front and back glenn1 Dryer Repair 1 11-26-2007 04:43 PM
cannot put drum belt back on tight frank Dryer Repair 1 08-10-2007 09:37 PM
