| » GE washer won't spin and smells like its burning |
Model Number: WBB3300A2WW Brand: GE Age: 1 - 5 years
When I turn the washer on, it fills up with water, but then it just sits and does not agitate. When it goes through the spin cycle it may spin for a few seconds, but then it stops and it starts to smell like something is burning. When it comes to the end of the cycle, it drains the water out, but the clothes are still pretty wet because it doesn't spin dry. I checked in the front panel for any errant laundry and there is none. The fan on the bottom right inside the control panel is working just fine. I can't afford to buy a new washer! Please help
Take off the front and see if the transmission pulley turns easily, and if the motor will run with the belt off. If it does, and the transmission pulley does not turn then you probably have a problem inside the transmission, which could be the brakes which are contained inside the transmission housing.
If this is the case, and funds are tight I recommend you invest in a good used washer instead of trying to repair yours. A nice top loading Kenmore, Whirlpool or Roper will do a fine job for you and be much less likely to need repair, and if it does, the repairs are inexpensive and pretty easy.
__________________
| Display Modes | |
| Whirlpool washer smells like something is burning | D Will | Washer Repair | 4 | 08-06-2011 08:42 AM |
| Kenmore washer smells like something burning | mjd | Washer Repair | 0 | 04-16-2010 07:20 AM |
| Stackable Washer - won't drain, smells like its burning! | Thegirls | Washer Repair | 4 | 01-27-2010 12:35 PM |
| Dryer smells like burning, won't start | bignick2184 | Dryer Repair | 1 | 08-28-2009 05:38 PM |
| belt smells like burning | fedexsteve | Washer Repair | 1 | 09-08-2008 04:16 PM |
