My Kenmore front loading washer is depositing a dirty streak on the clean clothes- it looks like someone has dipped a string in dirty oil and thrown it across the clean clothes- is there a clean out I missed or is a part failing and somehow squirting into the tub? This is perplexing and frustrating. I have tried running washing machine cleaner through it but it didn't help. Thanks
Sounds like the seal on the spider shaft has failed. Has the machine sounded noisier than normal recently? This would indicate that the bearings and seal are 'on the way out'.
