MY WASHER WILL ADGITATE BUT NOT DRAIN OR SPIN, I CAN HEAR A NOISE THAT SOUNDS LIKE THE PUMP TRYING TO WORK, BUT NOTHING HAPPENS. IF I LET IT FOR A WHILE AND RESET IT OR UNPLUG OR EVEN RESTART THE CYCLE SOMETIMES IT WILL WORK FINE. I CAN MANUALLY DRAIN THE TUB BY LOWERING THE HOSE TO THE FLOOR, BUT IT STILL WONT SPIN. I AM WONDERING IF IT IS THE WATER LEVEL SWITCH?
