Discuss
Maytag SE1000 Motor switch
 in
Washer Repair
I replaced my washer motor part# 2-1664-12 mod# S67PXHEH-6642 with a motor that was told to me
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag SE1000 Motor switch
  #1 (permalink)
Old 08-22-2008, 03:27 PM
DNyq DNyq is offline
Junior Member
DNyq is on a distinguished road
Default Maytag SE1000 Motor switch
Model Number: SE1000   Brand: Maytag   Age: More than 10 years
I replaced my washer motor part# 2-1664-12 mod# S67PXHEH-6642 with a motor that was told to me would work part#6 2307690 mod#S67PXKGC7722. I am trying to check the motor switch and my new motor does not seem to have a centrifigul switch like my old motor, nor does it look like it has a location for the motor switch. I have ordered a motor switch that will work on my old motor. When testing the old motor switch it tests bad. Hopefully this will get the washer to spin for more than 10 seconds.
Any help would be greatly appreciated.
Related Models
Maytag SE1000 Stacked Laundry - Ele
Maytag SE1000T Stacked Laundry - Ele
Maytag SE7800 Stacked Laundry - Ele
Whirlpool SE950PEKW0
Whirlpool SE950PEKW1
Whirlpool SE950PEPW0
Whirlpool SE950PERW0
Whirlpool SE950PERW1
Whirlpool SE950PERW2
Whirlpool SE950PERW3
Whirlpool SE950PERW4
Whirlpool SE950PERW5
Whirlpool SE950PERW6
Whirlpool SE950PERW7
Whirlpool SE950PERW8
Whirlpool SE950PERW9
Whirlpool SE950PSKW0
Whirlpool SE950PSKW1
Whirlpool SE950PSPW0
Whirlpool SE953PEKT0
Whirlpool SE953PEKT1
Whirlpool SE953PSKT0
Whirlpool SE953PSKT1
Whirlpool SE960PEPW0
Whirlpool SE960PEPW1
Whirlpool SE960PEPW2
Whirlpool SE960PEPW3
Whirlpool SE960PEPW4
Whirlpool SE960PEPW5
Whirlpool SE960PEPW6
Whirlpool SE960PEYN1
Whirlpool SE960PEYN2
Whirlpool SE960PEYN3
Whirlpool SE960PEYW0
Whirlpool SE960PEYW1
Whirlpool SE960PEYW2
Whirlpool SE960PEYW3
Maytag SE9900 Stacked Laundry - Ele
Whirlpool SEC350XW0
Whirlpool SEC350XX1
Whirlpool SEDS800HQ0
Whirlpool SEDS800JQ0
Whirlpool SEDS800JQ1
Whirlpool SEDS800MQ0 29"electric Dryer
Whirlpool SEDS800MQ1 29"electric Dryer
Whirlpool SEDX600HQ0
Whirlpool SEDX600JQ0
Whirlpool SEDX600JQ1
Whirlpool SEDX600MQ0 29"electric Dryer
Whirlpool SEDX600MQ1 29"electric Dryer
Amana SEFS65D Commercial Microwaves
Jenn-Air SEG196 Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SEG196-C Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SEG196B Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SEG196B-C Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SEG196W Range - S/c S/i Gas & Elec Duel Fuel
Jenn-Air SEG196W-C Range - S/c S/i Gas & Elec Duel Fuel
Whirlpool SEP340XX0
Whirlpool SEP340XX1
White Westinghouse SER341AQ0 Dryer - W.west
White Westinghouse SER341AQ1 Dryer - West/grupo Gomo
White Westinghouse SER341AQ2 White Westinghouse/electric Dryer
White Westinghouse SER341AS0 Dryer - W.west
White Westinghouse SER341AS1 Dryer - West/grupo Gomo
White Westinghouse SER341AS2 White Westinghouse/electric Dryer
Whirlpool SES370XX0
Whirlpool SES374HQ0
Whirlpool SES374HQ1
Whirlpool SES380MS0 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool SF0100EKW0
Whirlpool SF0100EKW1
Whirlpool SF0100EKW2
Whirlpool SF0100ERW0
Whirlpool SF0100ERW1
Whirlpool SF0100ERW2
Whirlpool SF0100ERW3
Whirlpool SF0100ERW4
Whirlpool SF0100ERW5
Whirlpool SF0100ERW6
Whirlpool SF0100ERW7
Whirlpool SF0100ERW8
Whirlpool SF0100SKW0
Whirlpool SF0100SKW1
Whirlpool SF0100SRW0
Whirlpool SF0100SRW1
Whirlpool SF0100SRW2
Whirlpool SF0100SRW3
Whirlpool SF0100SRW4
Whirlpool SF0100SRW5
Whirlpool SF0100SRW6
Whirlpool SF0100SRW7
Whirlpool SF0100SRW8
Whirlpool SF0100SRW9
Whirlpool SF0100SYN0
Whirlpool SF0100SYW0
Whirlpool SF0105EPW0
Whirlpool SF0105SPW0
Whirlpool SF010EERW0
Whirlpool SF010EERW1
Whirlpool SF010EERW2
Whirlpool SF010ESPW0
Whirlpool SF010ESRW0
Whirlpool SF010ESRW1
Whirlpool SF010ESRW2
Whirlpool SF0140SRW0
Whirlpool SF0140SRW1
Whirlpool SF0140SRW2
Whirlpool SF0140SRW3
Whirlpool SF0140SRW4
Whirlpool SF0140SRW5
Whirlpool SF0140SRW6
Whirlpool SF110AXSQ0 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF110AXSQ1 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF111PXSQ0 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF111PXSQ1 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF114PXSB0 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF114PXSB1 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF114PXSB2 30" Gas Freestanding Standard Clean Range Electronic Ignition
Whirlpool SF114PXSQ0 30" Gas Freestanding Standard Clean Range Electronic Ignition
  #2 (permalink)
Old 08-22-2008, 03:48 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
I'm not sure where you purchased your motor but the part number should be 201805 and the switch is sold separately
Nat
  #3 (permalink)
Old 08-29-2008, 07:34 AM
Junior Member
Default
I obtained a new motor switch and installed it on the "old motor". I then started the spin cycle "without the drive belt on" the machine pumped for about 1 minute before I powered the unit down. I then attached the drive belt and tried a full wash cycle. The machine filled but when the motor was activated the motor hummed with no movement, after about a 30 seconds a blue arc happened and then there was no sound from the motor. I did not smell electrical. I went to bed dejected and mad at myself. The next morning, just on the off chance the machine repaired itself or I had a bad dream, I tried the machine the machine immediately went into aggitation and after 10 seconds billowed smoke quite thick and white I shut the machine off, went to work, and tried to think of an excuse to tell my wife when she smells what I have done. I now believe that the motor switch was part of the problem. (I have changed all of the smoke detector batteries in the basement and do not suggest to test them in this mannor.)
There does not appear to be any black or charing around the connections.
I have tried the spin cycle without the drive belt and the water has pumped out. The drum seams to be a little tight or stiff to move
1. What could possibly be the origination of the big smoke?
2. Is the belt slipping? The smoke billowed so fast and thick I could not tell where it came from and the machine was still aggitating.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag SE1000 won't spin or drain DNyq Washer Repair 8 08-16-2008 01:33 PM
Motor switch or timer? jakevi Washer Repair 4 03-06-2008 10:28 AM
maytag lid switch benjakiah Washer Repair 3 02-03-2008 07:17 PM
motor switch poboy Dryer Repair 0 11-23-2007 07:13 PM
maytag switch removal jerman Washer Repair 1 10-13-2007 09:11 PM
