Discuss
Won't spin between cycles
 in
Washer Repair
I'm having troubles with my washing machine. When it starts its spin cycles, it won't reach its capacity.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Won't spin between cycles
  #1 (permalink)
Old 08-22-2008, 01:04 PM
dcavers dcavers is offline
Junior Member
dcavers is on a distinguished road
Default Won't spin between cycles
Brand: Crosley   Age: 1 - 5 years
I'm having troubles with my washing machine. When it starts its spin cycles, it won't reach its capacity. If I open and close the lid a couple times, it reaches capacity. Whats wrong with it? Please help
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-22-2008, 03:07 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
please post your model number off the unit.
  #3 (permalink)
Old 08-23-2008, 07:40 PM
Junior Member
Default
I'm not sure what the model # is, but I'll give you what I can see off the machine. It is EEV99413. Hope this helps, otherwise you're going to have to tell me where to find it.
  #4 (permalink)
Old 08-23-2008, 07:46 PM
Senior Expert
APP Volunteer
Default
Raise the lid about 3/4 way up, look under the hing area on the washer intself, there should be a tag there with a model & serial number
Nat
  #5 (permalink)
Old 08-23-2008, 07:55 PM
Junior Member
Default
There is a sticker on the top right hand side of the lid, but it doesn't have any model # on it.
  #6 (permalink)
Old 08-23-2008, 07:58 PM
Junior Member
Default
I found it, the model # is CW6500W and the serial # is 10894060EA
  #7 (permalink)
Old 08-23-2008, 08:06 PM
Senior Expert
APP Volunteer
Default
My guess would be the lid switch is going bad, part number AP4008752, if it will continue after shutting the lid a few times
Nat
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore washer won't spin, agitate, or go through cycles asnapp Washer Repair 10 08-26-2008 07:53 PM
Loud thumping sound during spin cycles bigjoesbt Washer Repair 1 06-12-2008 03:41 AM
Loud noise at the end of all spin cycles ladyrazorback Washer Repair 1 04-14-2008 10:48 AM
Spin and pump cycles stop and start, washer won't drain grosshaus Washer Repair 1 03-31-2008 03:10 PM
GE Space Savor Washer goes through all cycles but doesn't spin bobbertj Washer Repair 0 02-07-2008 02:18 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
