Discuss
Washer does nothing
 in
Washer Repair
My front loader will only fill and drain. I have turn the dial to other selections, but it will not
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer does nothing
  #1 (permalink)
Old 08-21-2008, 05:16 PM
Mark50 Mark50 is offline
Junior Member
Mark50 is on a distinguished road
Default Washer does nothing
Model Number: WSXH208A1WW   Brand: GE   Age: 5 - 10 years
My front loader will only fill and drain. I have turn the dial to other selections, but it will not do anything. The motor will not run. There was a trouble shooting guide which I followed. It tells you to check the resistance across the 6-pins to the circuit board. This checks OK at 3 ohms. Then you are to check voltage at the 10 pin. The voltage is OK there too. Then check resistance for the motor it wasn't suppose to be over 2.6 ohms +-7% I got 3.0 ohms. So I replaced the motor NO GOOD. I get 3.0 ohms with the new. I then checked the timer. voltage is what it is suppose to be, and the N/C and N/O pins are correct. The door switch is also good, because it wouldn't fill CORRECT. Any help would be greatly appreciated. I am lost as what to do next
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-21-2008, 06:04 PM
abadfish66's Avatar
abadfish66 abadfish66 is offline
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
On the speed control unit, check the fuse, if open replace the speed control unit. If fuse is good then remove the 6 pin plug from the speed control and measure resistance between pins 1 and 2, 2 and 3, then 3 and 1 on the speed control board. If your meter reads anything other than 3 meg ohms +- 10% replace the speed control unit. Remember, the timer does not advance until the speed control unit tells it to move forward, so I doubt the timer is at fault.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!!
Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up.
  #3 (permalink)
Old 08-21-2008, 06:23 PM
Junior Member
Default
I did measure the resistance on the pins and got 3 ohms, Also the fuse on the speed control was good
  #4 (permalink)
Old 08-21-2008, 06:26 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
3ohms or 3 meg ohms, big difference. The problem you describe are most likely the speed control, door latch, or even could be the dispenser door switch. i believe your model has a magnet switch. You can check this by putting a paperclip on the right side of the dispenser when opened. The magnet should be just behind the front panel of the dispenser.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
