Washer will not drain. Performed diagnostic checks C:01 thru C:08. Checked and cleaned drain filter. Diagnostic test C:06 turns on drain pump which activates but no water displaced. Got it to work once with drain hose in bucket. Appeared to drain ok. Went back through test, would not displace water. Removed pump from housing still hooked up to electrical, ran test, pump activates every time. Re-installed pump, no water displacement. Impeller looks great, Cannot find any blockage. Instructions on paperwork say to replace pump. Don't know where to turn next. Thinking about getting another pump but don't want to spend the money if it won't fix the problem.
Sounds like there is a clog somewhere. You may want to check ALL hoses to and from the drain pump.
