Discuss
Maytag neptune doesn't spin fast
 in
Washer Repair
Neptune does not do the high speed spin ,just low.Replaced the control panel and wax motor three years ago,lock light
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag neptune doesn't spin fast
  #1 (permalink)
Old 08-02-2010, 12:18 PM
Junior Member
jjberta001 is on a distinguished road
Default Maytag neptune doesn't spin fast
Model Number: Neptune front loader   Brand: Maytag   Age: 5 - 10 years
Neptune does not do the high speed spin ,just low.Replaced the control panel and wax motor three years ago,lock light comes on but still doesn't hit high speed spin even with most of the clothes out,any ideas ? Have it on white cycle also. Motor is not noisy and doesn't vibrate.Washer is level and on a solid tile floor.
Related Models
Norge NER1360ACW RANGE- F/S STD ELE
Admiral NER1360AGH RANGE- F/S STD ELE
Norge NER3540ACW RANGE- S/C F/S ELE
Norge NER3760ACW RANGE- S/C F/S ELE
Bosch NES732 UC
Bosch NES735 UC
Bosch NES736 UC
Bosch NES932 UC
Bosch NES935 UC
Bosch NES936 UC
Norge NEW2G1 RANGE- F/S STD ELE
Norge NEW2H0 RANGE- F/S STD ELE
Norge NEW2H1 RANGE- F/S STD ELE
Norge NEW3G1 RANGE- F/S STD ELE
Norge NEW3G8AC RANGE- S/C F/S ELE
Norge NEW3G8CV RANGE- S/C F/S ELE
Norge NEW3G8CX RANGE- S/C F/S ELE
Norge NEW3G8DEV RANGE- S/C F/S ELE
Norge NEW3G8DX RANGE- S/C F/S ELE
Norge NEW3G8EV RANGE- S/C F/S ELE
Norge NEW3G8EVW RANGE- S/C F/S ELE
Norge NEW3H2EX RANGE- F/S STD ELE
Norge NEW3H8CVW RANGE- S/C F/S ELE
Norge NEW3H8CX RANGE- S/C F/S ELE
Norge NEW3H8STVW-EV RANGE- S/C F/S ELE
Norge NEW3J8EV RANGE- S/C F/S ELE
Norge NEW6G6CLW RANGE- F/S CONT CLEAN ELE
Norge NEW6H6CLW RANGE- F/S CONT CLEAN ELE
Bosch NEZ1000
Bosch NEZ1010
Bosch NEZ1020
Bosch NEZ1050
Bosch NEZ1055
Bosch NEZ1070
Bosch NEZ1075
Bosch NEZ1100
Frigidaire NFTR18X4LB0 REFRIGERATOR
Frigidaire NFTR18X4LB1 REFRIGERATOR
Frigidaire NFTR18X4LB2 REFRIGERATOR
Frigidaire NFTR18X4LB4 FRIGIDAIRE/REFRIGERATOR
Frigidaire NFTR18X4LB6 REFRIGERATOR
Frigidaire NFTR18X4LS2 REFRIGERATOR
Frigidaire NFTR18X4LS3 FRIGIDAIRE/REFRIGERATOR
Frigidaire NFTR18X4LS4 REFRIGERATOR
Frigidaire NFTR18X4LS5 REFRIGERATOR
Frigidaire NFTR18X4LS6 REFRIGERATOR
Frigidaire NFTR18X4LW0 REFRIGERATOR
Frigidaire NFTR18X4LW1 REFRIGERATOR
Frigidaire NFTR18X4LW2 REFRIGERATOR
Frigidaire NFTR18X4LW4 FRIGIDAIRE/REFRIGERATOR
Frigidaire NFTR18X4LW6 REFRIGERATOR
Maytag NFW7200TW10 AUTOMATIC WASHER
Maytag NFW7200TW11 AUTOMATIC WASHER
Maytag NFW7300WW00 AUTOMATIC WASHER
Maytag NFW7500VM00 AUTOMATIC WASHER
Maytag NFW7500VM01 AUTOMATIC WASHER
Maytag NFW7500VW00 AUTOMATIC WASHER
Maytag NFW7500VW01 AUTOMATIC WASHER
Maytag NFW7600XW00 AUTOMATIC WASHER
Amana NG2119 WASHER-TOP LOADING
Amana NG3319 WASHER-TOP LOADING
Amana NG3519 WASHER-TOP LOADING
Amana NG4319 WASHER-TOP LOADING
Amana NG4519 WASHER-TOP LOADING
Amana NG4619 WASHER-TOP LOADING
Amana NG4719 WASHER-TOP LOADING
Amana NG4819 WASHER-TOP LOADING
Amana NG5319 WASHER-TOP LOADING
Amana NG5519 WASHER-TOP LOADING
Amana NG6319 WASHER-TOP LOADING
Amana NG6339 WASHER-TOP LOADING
Amana NG6519 WASHER-TOP LOADING
Amana NG6539 WASHER-TOP LOADING
Amana NG6619 WASHER-TOP LOADING
Amana NG6819 WASHER-TOP LOADING
Amana NG7319 WASHER-TOP LOADING
Amana NG7519 WASHER-TOP LOADING
Amana NG8339 WASHER-TOP LOADING
Amana NG8539 WASHER-TOP LOADING
Amana NG8639 WASHER-TOP LOADING
Amana NG8839 WASHER-TOP LOADING
Norge NGA2G1K RANGE- F/S STD GAS
Norge NGA2H0 RANGE- F/S STD GAS
Norge NGA2H1 RANGE- F/S STD GAS
Norge NGA2HK0 RANGE- F/S STD GAS
Norge NGA2HK1 RANGE- F/S STD GAS
Norge NGA3G1 RANGE- F/S STD GAS
Norge NGA3H2AV RANGE- F/S STD GAS
Norge NGA3H8BCK RANGE- S/C F/S GAS
Norge NGA3H8EKV RANGE- S/C F/S GAS
Norge NGA3H8EKX RANGE- S/C F/S GAS
Norge NGA3J3KSX RANGE- F/S STD GAS
Norge NGA3J8EKSVW RANGE- S/C F/S GAS
Norge NGA3M8CKV RANGE- S/C F/S GAS
Norge NGA3M8TKS RANGE- S/C F/S GAS
Norge NGA6H2GKLW RANGE-F/S CONT CLEAN GAS
Norge NGA6H2GW RANGE- F/S STD GAS
Norge NGA6H2KLW RANGE-F/S CONT CLEAN GAS
Norge NGA6H6GW RANGE- F/S STD GAS
Norge NGA6H6W RANGE- F/S STD GAS
Maytag NGD4500VQ0 29" GAS DRYER
Maytag NGD4800VQ0 29" GAS DRYER
Maytag NGD4800VQ1 29" GAS DRYER
Maytag NGD5100TQ0 29" GAS DRYER
Maytag NGD5100TQ1 29" GAS DRYER
Maytag NGD5200TQ0 29" GAS DRYER
Maytag NGD5240TQ0 29" GAS DRYER
Maytag NGD5400TQ0 29" GAS DRYER
Maytag NGD5500TQ0 29" GAS DRYER
Maytag NGD5800TQ0 29"GAS DRYER
Maytag NGD7200TW10 27" GAS DRYER
Maytag NGD7500VM1 GAS DRYER
Maytag NGD7500VW0 GAS DRYER
Maytag NGD7500VW1 GAS DRYER
Norge NGF3H8EKV RANGE- S/C F/S GAS
Bosch NGP732 UC (FD 8202-)
Bosch NGP735 UC (FD 8202-)
Bosch NGP736 UC (FD 8202-)
Bosch NGP932 UC/01
Bosch NGP935 UC/01
  #2 (permalink)
Old 08-02-2010, 01:45 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Are you sure the machine spins but only slow, it is not attempting to re distribute a off balanced load(tumbles, stops then tumbles again)?
If you have a MAH3000,MAH4000 or MAH5500A model.
Suggest you check the motor control harness and connections at the P4 connector on the machine control board(control panel) and the JP4 connector at the motor control board(inside of cabinet on right side of base).
Check for loose pins and terminals in connectors for tight fit.
Check all wires end to end for closed circuit, If all OK, replace the motor control board.
If you have a MAH5500B or MAH7500B model
The checks are the same but connections are labelled different.
The connector at the machine control board is labled P2,and the motor control board is still JP4.If all checks are OK you will need a motor control board.
Quite often, checking and cleaning the pins, wires and connections, solves the problem, but not always.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 08-03-2010, 10:53 AM
Junior Member
Default Slow spinner
Model is the mah4000 and I noticed as I was pulling the machine out that it had a lot of water in it,is this normal or because it is not spinning correctly ? I checked it yesterday with only a few garments in it so balance shouldn't be an issue. Will try and get to it today thanks for the response, Joe
  #4 (permalink)
Old 08-03-2010, 11:15 AM
Senior Expert
Default
Joe,
This machine, as well as most modern machines, have an electric powerred pump,(independant of motor, belt etc.
In most cases that pump either works or not, if there is something clogging the pump, it usually makes noise.
Since you are going to be behind it, you may want to check for a clog of lint or something similar in the hose or pump entrance.
If you allow that unit to fill and then drain the tub it should be empty in 45 seconds.
Also the tub counter balance, (front of the tub) is a fluid filled assembly, and you can hear a sloshing noise if the tub or machine is moved.
If there is no water visible in the bottom of the tub or no stagnant odor from the tub, there's a 98% chance the pump is working and draining proper.
And we're back to the motor control board and or harness for a slow spin problem.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag neptune no spin cycle actondale Washer Repair 10 08-02-2012 07:59 PM
Maytag Neptune Super Stack will not spin while in spin cycle. Vohn Washer Repair 2 11-04-2010 08:30 AM
Another Maytag Neptune won't spin jklingel Washer Repair 2 04-25-2009 08:02 PM
Maytag Neptune Won't Spin Again normas Washer Repair 5 10-31-2008 10:12 AM
Maytag won't spin fast enough. tomatofarmer Washer Repair 1 05-19-2008 04:01 AM
