Discuss
non spinning washer
 in
Washer Repair
have a kenmore which just stopped (with a bang). It doesn't seem to want to rinse or spin but I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » non spinning washer
  #1 (permalink)
Old 08-02-2010, 07:40 AM
Junior Member
sckibby is on a distinguished road
Default non spinning washer
Model Number: 11028942890   Brand: Kenmore   Age: More than 10 years
have a kenmore which just stopped (with a bang). It doesn't seem to want to rinse or spin but I did get the tub to empty and the motor does still run. It had been making noises when it would "shift" from agitate to rinse or spin. from browsing the forum I believe it may be the motor coupling as the motor is still running when the setting is spin but nothing moves. Is this likely correct and if so how big of a job is it and does any one have a diagram of the fix?
Thanks for the help.
Ads By Google
Related Models
Kenmore 11028942890 Residential Washers
Kenmore 11028942891 AUTOMATIC WASHER
Kenmore 11028944890 Residential Washers
Kenmore 11028944891 AUTOMATIC WASHER
Kenmore 11028972890 AUTOMATIC WASHER
Kenmore 11028972891 AUTOMATIC WASHER
Kenmore 11028974890 AUTOMATIC WASHER
Kenmore 11028974891 AUTOMATIC WASHER
Kenmore 1102970093 COMPACT AUTOMATIC WASHER
Kenmore 11029802890 AUTOMATIC WASHER
Kenmore 11029812890 AUTOMATIC WASHER
Kenmore 11029812891 AUTOMATIC WASHER
Kenmore 11029842990 WASHER
Kenmore 11029842991 AUTOMATIC WASHER
Kenmore 11029852990 AUTOMATIC WASHER-GALAXY
Kenmore 11029852991 AUTOMATIC WASHER
Kenmore 11029852992 AUTOMATIC WASHER
Kenmore 11029882890 AUTOMATIC WASHER
Kenmore 11029882891 AUTOMATIC WASHER
Kenmore 11029884890 AUTOMATIC WASHER
Kenmore 11029884891 AUTOMATIC WASHER
Kenmore 11029892990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029894990 AUTOMATIC WASHER-TECH SHEET
Kenmore 11029962890 AUTOMATIC WASHER
Kenmore 11029962891 AUTOMATIC WASHER
Kenmore 1103348565 GEARCASE
Kenmore 110357116 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357177 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110357970 BASKET DRIVE AND BRAKE ASM
Kenmore 110357972 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358364 BASKET DRIVE AND BRAKE ASM
Kenmore 110358365 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358371 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358483 GEARCASE ASM
Kenmore 110358484 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358485 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358487 GEARCASE AND SUPERSTRUCTURE
Kenmore 110358507 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358795 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110358841 GEARCASE AND SUPERSTRUCTURE
Kenmore 110359175 BASKET DRIVE & BRAKE ASM
Kenmore 110359178 GEAR CASE AND SUPERSTRUCTURE
Kenmore 110359279 GEARCASE PARTS
Kenmore 110359517 BASKET DRIVE AND BRAKE PARTS
Kenmore 110359699 BASKET DRIVE AND BRAKE PARTS
Kenmore 110360093 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110360867 DOLE MIXING VALVE ASSEMBLY
Kenmore 110360868 AMERICAN STANDARD MIXING VALVE ASSEMBLY
Kenmore 110362101 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110362821 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110362901 GEARCASE ASM
Kenmore 110363000 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110363076 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110363082 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364443 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364444 BASKET DRIVE AND BRAKE PARTS
Kenmore 110364446 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364494 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110364760 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365011 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365012 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365013 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365014 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365196 GEARCASE AND SUPERSTRUCTURE
Kenmore 110365359 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365712 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365859 GEARCASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110365948 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110366559 GEARCASE AND SUPERSTRUCTURE
Kenmore 110366660 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110366990 BASKET DRIVE & BRAKE ASM
Kenmore 110367551 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110367593 GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 1103733107 KENMORE PORTABLE AUTOMATIC WASHER
Kenmore 110386842 WATER SAVER
Kenmore 110387948 BRAKE AND DRIVE TUBE
Kenmore 110388951 BRAKE AND DRIVE TUBE
Kenmore 110388952 BRAKE AND DRIVE TUBE
Kenmore 110389246 GEARCASE PARTS
Kenmore 110395055 GEARCASE AND SUPERSTRUCTURE
Briggs & Stratton 110402-0180-E1 ENGINE
Kenmore 11049182992 WASHER
Kenmore 11049722990 AUTOMATIC WASHER
Kenmore 11049722991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11049722992 COMPACT WASHER
Kenmore 11051115 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051140 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051309 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11051730 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055592 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055593 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055594 WORM GEAR CASE AND MOTOR ASSEMBLY
Kenmore 11055610 WORM GEAR CASE ASSEMBLY
Kenmore 11055614 WORM GEAR CASE ASSEMBLY
Kenmore 11056171 WORM GEAR CASE ASSEMBLY
Kenmore 11056172 WORM GEAR CASE ASSEMBLY
Kenmore 11056464 WORM GEAR CASE ASSEMBLY
Kenmore 11057624 KENMORE PERMANENT INSTALLATION CONV KIT
Kenmore 11057929 KENMORE DUAL AGITATOR KIT
Kenmore 1105809106 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809500 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809502 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809503 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809702 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809703 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809704 KENMORE GAS COMBINATION WASHER-DRYER
Kenmore 1105809800 KENMORE GAS CONBINATION WASHER-DRYER
Kenmore 1105907400 KENMORE GAS DRYER
Kenmore 1105907500 KENMORE GAS DRYER
Kenmore 1105907501 KENMORE GAS DRYER
Kenmore 1105907600 KENMORE GAS DRYER
Kenmore 1105907610 KENMORE GAS-DRYER
Kenmore 1105907700 KENMORE GAS DRYER
Kenmore 1105907710 KENMORE GAS DRYER
Kenmore 1105907720 KENMORE GAS DRYER
Kenmore 1105907721 KENMORE GAS DRYER
Kenmore 1105907730 KENMORE GAS DRYER
Kenmore 1105907800 KENMORE GAS DRYER
Kenmore 1105907801 KENMORE GAS DRYER
Kenmore 1105907802 KENMORE GAS DRYER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer not spinning shipee1 Washer Repair 0 04-08-2010 02:03 PM
Washer no spinning royrodgers Washer Repair 1 12-28-2009 01:42 AM
Washer Not Spinning rcafan Washer Repair 1 12-01-2009 10:49 AM
washer not spinning frankie40 Dishwasher Repair 5 12-22-2008 01:56 AM
washer not spinning nbrown9 Washer Repair 7 08-19-2008 01:35 PM
