| » Washer does not start or fill |
Model Number: LXR7244JQ0 Brand: Whirlpool Age: 1 - 5 years
The washer just totally stopped working. I had just washed a load of clothes and put them in the dryer. I went to put another load in and the water would not turn on. I did not smell anything, the timer moves around fine, I selected the cycle and pulled the knob, and nothing. It's like I can hear the timer trying to work, but nothing happens. I moved the timer around, and it would not fill on a rinse cycle, or a delicate cycle, it doesn't do anything.
How can I fix this? I have already had this washer fixed like 4 times for other reasons, but I cannot afford to get it serviced again, and also can't afford to buy a new washer right now (and I have dirty clothes piling up!!!). Any insight into this will be very greatly appreciated. Thank you. Last edited by sarahwhite914 : 08-20-2008 at 07:58 PM. |
Change your water temp first. If it works then it's the valve. If not it could be a number of problems.
Check your water valve on the back it may have clogged up, or you may need a new one Whirlpool part number is 285805 (AP# AP3094541). If in doubt go to a recycling center to see if they have any Whirlpool washer setting around and talk them out of a couple of water valves ;o) Hope that helps Nat Last edited by libertyappl : 08-20-2008 at 09:47 PM. |
| Display Modes | |
| Washer will only Fill | sailfastnu | Washer Repair | 2 | 08-14-2008 06:37 AM |
| Washer will fill only, but will not run. | spectra57 | Washer Repair | 5 | 08-09-2008 05:00 AM |
| Washer will not fill | johnkh1949 | Washer Repair | 0 | 06-16-2008 11:08 AM |
| Washer will not fill | roddude32 | Washer Repair | 3 | 12-11-2007 07:14 PM |
| washer doesn't fill | brianv | Washer Repair | 1 | 10-24-2007 10:05 PM |
