Discuss
Washer does not start or fill
 in
Washer Repair
The washer just totally stopped working. I had just washed a load of clothes and put them in the dryer.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer does not start or fill
  #1 (permalink)
Old 08-20-2008, 03:05 PM
sarahwhite914 sarahwhite914 is offline
Junior Member
sarahwhite914 is on a distinguished road
Angry Washer does not start or fill
Model Number: LXR7244JQ0   Brand: Whirlpool   Age: 1 - 5 years
The washer just totally stopped working. I had just washed a load of clothes and put them in the dryer. I went to put another load in and the water would not turn on. I did not smell anything, the timer moves around fine, I selected the cycle and pulled the knob, and nothing. It's like I can hear the timer trying to work, but nothing happens. I moved the timer around, and it would not fill on a rinse cycle, or a delicate cycle, it doesn't do anything.
How can I fix this? I have already had this washer fixed like 4 times for other reasons, but I cannot afford to get it serviced again, and also can't afford to buy a new washer right now (and I have dirty clothes piling up!!!). Any insight into this will be very greatly appreciated.
Thank you.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-20-2008, 09:44 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Change your water temp first. If it works then it's the valve. If not it could be a number of problems.
Check your water valve on the back it may have clogged up, or you may need a new one Whirlpool part number is 285805 (AP# AP3094541). If in doubt go to a recycling center to see if they have any Whirlpool washer setting around and talk them out of a couple of water valves ;o)
Hope that helps
Nat
  #3 (permalink)
Old 08-21-2008, 07:51 PM
Junior Member
Default
I did not try it yet, but I do thank you for your reply.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will only Fill sailfastnu Washer Repair 2 08-14-2008 06:37 AM
Washer will fill only, but will not run. spectra57 Washer Repair 5 08-09-2008 05:00 AM
Washer will not fill johnkh1949 Washer Repair 0 06-16-2008 11:08 AM
Washer will not fill roddude32 Washer Repair 3 12-11-2007 07:14 PM
washer doesn't fill brianv Washer Repair 1 10-24-2007 10:05 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
