Discuss
makes intermittent noise during agitation
 in
Washer Repair
our washing machine is making a loud, intermittent, grinding noise during the agitation cycle. it sounds almost like worn gears
Appliance Repair Forum > Appliance Repair Help > Washer Repair » makes intermittent noise during agitation
  #1 (permalink)
Old 08-19-2008, 09:56 PM
Junior Member
mattr is on a distinguished road
Default makes intermittent noise during agitation
Model Number: KAWE560WWH3   Brand: Kitchen Aid   Age: More than 10 years
our washing machine is making a loud, intermittent, grinding noise during the agitation cycle. it sounds almost like worn gears slipping, intermittently, at a beat of about 2 "grinds" every second. The clothes are moving in a counter-clockwise circle, way faster than normal, almost as if the agitator were not working. Do I need to replace the transmission, or the clutch, or both?
Related Models
Whirlpool KAWE560WWH3
Whirlpool KAWE564WAL0
Whirlpool KAWE564WAL1
Whirlpool KAWE564WAL2
Whirlpool KAWE564WAL3
Whirlpool KAWE564WWH0
Whirlpool KAWE564WWH1
Whirlpool KAWE564WWH2
Whirlpool KAWE564WWH3
Whirlpool KAWE565BWH0 AUTOMATIC WASHER
Whirlpool KAWE565BWH1 AUTOMATIC WASHER
Whirlpool KAWE567WWH0
Whirlpool KAWE570BWH0 AUTOMATIC WASHER
Whirlpool KAWE570BWH1 AUTOMATIC WASHER
Whirlpool KAWE577BWH0 AUTOMATIC WASHER
Whirlpool KAWE577BWH1 AUTOMATIC WASHER
Whirlpool KAWE578BAL0
Whirlpool KAWE578BAL1
Whirlpool KAWE650VAL0
Whirlpool KAWE650VWH0
Whirlpool KAWE660WAL0
Whirlpool KAWE660WAL1
Whirlpool KAWE660WAL2
Whirlpool KAWE660WAL3
Whirlpool KAWE660WWH0
Whirlpool KAWE660WWH1
Whirlpool KAWE660WWH2
Whirlpool KAWE660WWH3
Whirlpool KAWE665BWH0 AUTOMATIC WASHER
Whirlpool KAWE667BWH0
Whirlpool KAWE667BWH1 AUTOMATIC WASHER
Whirlpool KAWE668BAL0
Whirlpool KAWE668BAL1
Whirlpool KAWE670BAL0
Whirlpool KAWE670BWH0
Whirlpool KAWE670BWH1
Whirlpool KAWE677BWH0
Whirlpool KAWE677BWH1
Whirlpool KAWE678BAL0
Whirlpool KAWE678BAL1
Whirlpool KAWE679BBL0
Whirlpool KAWE679BBL1
Whirlpool KAWE700TWH0
Whirlpool KAWE742BAL0
Whirlpool KAWE742BWH0
Whirlpool KAWE742VAL0
Whirlpool KAWE742VWH0
Whirlpool KAWE742WAL0
Whirlpool KAWE742WAL1
Whirlpool KAWE742WAL2
Whirlpool KAWE742WAL3
Whirlpool KAWE742WWH0
Whirlpool KAWE742WWH1
Whirlpool KAWE742WWH2
Whirlpool KAWE742WWH3
Whirlpool KAWE750VAL0
Whirlpool KAWE750VWH0
Whirlpool KAWE755VAL0
Whirlpool KAWE755VWH0
Whirlpool KAWE760WAL0
Whirlpool KAWE760WAL1
Whirlpool KAWE760WAL2 AUTOMATIC WASHER
Whirlpool KAWE760WAL3 AUTOMATIC WASHER
Whirlpool KAWE760WWH0
Whirlpool KAWE760WWH1
Whirlpool KAWE760WWH2
Whirlpool KAWE760WWH3
Whirlpool KAWE764WAL0
Whirlpool KAWE764WAL1
Whirlpool KAWE764WAL2
Whirlpool KAWE764WWH0
Whirlpool KAWE764WWH1
Whirlpool KAWE764WWH2
Whirlpool KAWE767BWH0
Whirlpool KAWE767WAL0
Whirlpool KAWE767WWH0
Whirlpool KAWE768BAL0
Whirlpool KAWE768BAL1
Whirlpool KAWE768BWH0
Whirlpool KAWE770BAL0
Whirlpool KAWE770BWH0
Whirlpool KAWE770BWH1
Whirlpool KAWE777BWH0
Whirlpool KAWE777BWH1
Whirlpool KAWE778BAL0
Whirlpool KAWE778BAL1
Whirlpool KAWE800SWH1
Whirlpool KAWE800TWH0
Whirlpool KAWE842WAL0
Whirlpool KAWE842WAL1
Whirlpool KAWE842WAL2
Whirlpool KAWE842WWH0
Whirlpool KAWE842WWH1
Whirlpool KAWE842WWH2
Whirlpool KAWE850VAL0
Whirlpool KAWE850VAL1
Whirlpool KAWE850VWH0
Whirlpool KAWE850VWH1
Whirlpool KAWE860WAL0
Whirlpool KAWE860WAL1
Whirlpool KAWE860WAL2
Whirlpool KAWE860WAL3
Whirlpool KAWE860WWH0
Whirlpool KAWE860WWH1
Whirlpool KAWE860WWH2
Whirlpool KAWE860WWH3
Whirlpool KAWE870BAL0
Whirlpool KAWE870BWH0
Whirlpool KAWE870BWH1
Whirlpool KAWE877BWH1
Whirlpool KAWE878BAL1
Whirlpool KAWE900SWH1
Whirlpool KAWE900SWH2
Whirlpool KAWE900TWH0
Whirlpool KAWE900TWH1
Whirlpool KAWE950VAL0
Whirlpool KAWE950VWH0
Whirlpool KAWE960WAL0
Whirlpool KAWE960WAL1
Whirlpool KAWE960WWH0
  #2 (permalink)
Old 08-20-2008, 06:45 AM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Can You Verify That The Agitator Is Actually Moving Back & Forth?
  #3 (permalink)
Old 08-20-2008, 09:13 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
With clothes in the washer, check that the upper section of the agitator is moving, if not you have worn out agitator cams.
__________________
  #4 (permalink)
Old 06-18-2011, 09:36 PM
Junior Member
Dr. E is on a distinguished road
Default KitchenAid KAWS977EQ0 noise during one-way agitation
Our Kitchenaid KAWS977EQ0 washer is grinding during agitation. Using the built-in test modes, the washer will fill, drain, agitate at all three speeds with no water or clothes, spin normally, and brake normally when done.
However, when filled with water, the agitator makes a slight grinding sound during low speed agitation; the tub does not spin (which is good), but the lower agitator moves forcefully clockwise, then grinds a bit as it returns (but it does return); the upper agitator behaves normally, rotating only one way. If clothes are added, they circulate top to bottom and stay pretty much in the same area of the tub as they should. So for the most part low speed agitation is okay.
At medium speed, the agitator makes a loud grinding sound, the lower agitator moves forcefully clockwise, but grinds loudly when it should return, so it moves clockwise continually, making a turn-grind-turn-grind-turn-grind sound; the upper agitator moves by fits and starts since the lower agitator never returns properly. The tub does not spin (good). The water whirls around clockwise (bad). If clothes are present, they quickly wrap around the agitator.
At high speed, the agitator does all that, but much worse.
Initially, I thought agitator dogs. Indeed 3 of the 4 were broken, but replacing them merely improved the action of the upper agitator. The grinding noise and the whirling clothes remained.
Then I suspected maybe a broken motor-to-gearcase coupler, but the existing coupler had been replaced in the last few years and was in great shape.
Next, I found a broken cam arm in the brake assembly, and replaced it without effect. Then I replaced the entire clutch, with no effect.
Then I opened the gearcase and replaced the spring though it appeared fine. Replacing the spring had solved a similar problem with another washer years ago, but in that case the original spring had broken. None of these things made any difference.
I am requesting help in diagnosing this problem and in selecting a path forward.
I could replace the gearcase, but if someone can offer some guidance I would rather fix this one. When the gearcase was out of the unit, it spun and agitated fine, just as it does when installed and runs with no load. So it seems mostly okay and I would hate to send it to the landfill when maybe all it needs is one or two parts replaced.
The spin section of the gearcase seems fine, so options seem to be:
1. I assembled something wrong, but of course the whole reason for disassembly was the initial problem which is unaffected, so maybe
it is assembled correctly but something is worn/broken/missing. No debris was in the bottom of the gearcase oil when I drained it.
2. New agitate cams (#13 and 14 on the exploded gearcase diagram).
3. New thrust bearing (#17 and 18) - could affect the overall height of the drive shaft. The existing bearing has a tiny dimple due to wear but nothing more.
4. New agitate gears and washer (#11, 15, and 29) - teeth could be worn on #11, or the splines inside #11 could be damaged or the mating splines on #15 could be damaged, or maybe they are just both gunked up (should have cleaned 'em when I had it open). I suspect something is keeping these two parts misaligned when the washer is under load.
5. Replace the entire agitate shaft (#7). Kind of a shotgun approach, but if several worn parts are contributing to misalignment, this could fix it.
6. Replace the entire gearcase (#1). But I would hate to trash the old, nearly-working one, and the washer is my only testbench for checking repairs under load.
7. Replace the entire washer - not too desirable given the performance of today's washers.
I would really appreciate any help or ideas on how to proceed with this.
  #5 (permalink)
Old 06-19-2011, 01:45 AM
Senior Expert
APP Volunteer
Default
I would pull the tranny, turn the coupler counterclockwise. If you feel "roughness", you have a bad tranny.
__________________
  #6 (permalink)
Old 06-20-2011, 10:40 PM
Junior Member
Default
OK, but what specifically inside a "bad tranny" would account for the symptoms I described?
  #7 (permalink)
Old 06-21-2011, 02:22 AM
Senior Expert
APP Volunteer
Default
Re-post as direct drive tranny repair, but I don't think anyone here repairs these, just too hard to fix.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Grinding noise during agitation Shadow99 Washer Repair 3 10-07-2013 02:04 PM
Maytag washer makes loud noise during agitation and spin brokewasher Washer Repair 1 08-23-2009 06:41 AM
No Agitation, Grinding noise harleyt Washer Repair 3 02-15-2009 09:24 AM
grinding noise during agitation kdeldridge Washer Repair 7 04-04-2008 06:24 PM
Washer noise during agitation insp-jim Washer Repair 5 01-08-2008 09:04 PM
