Discuss
Maytag Top load Washer died
 in
Washer Repair
Have an older (but working fine 'til now) Maytag Top Load washer. It just quit mid-cycle. I turned the dial
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Top load Washer died
  #1 (permalink)
Old 08-17-2008, 06:26 PM
Junior Member
TXwannabe is on a distinguished road
Default Maytag Top load Washer died
Model Number: LAT8705AAE   Brand: Maytag   Age: More than 10 years
Have an older (but working fine 'til now) Maytag Top Load washer. It just quit mid-cycle. I turned the dial and got it to spin and empty the water from the tub, but it won't do anything else. Suspect it may be a lid switch? The fuse in the switch assembly is OK, but how do I test the switch? Tried using my digital meter, but regardless of which 2 terminals I contact, cannot get the meter to register a change with the lid up or down. Is this indicative of a bad switch?
Related Models
Maytag LAT8705AAE WASHER-TOP LOADING
Maytag LAT8705AAM WASHER-TOP LOADING
Maytag LAT8706AAE WASHER-TOP LOADING
Maytag LAT8706AAM WASHER-TOP LOADING
Maytag LAT8714AAE WASHER-TOP LOADING
Maytag LAT8714AAL WASHER-TOP LOADING
Maytag LAT8714AAM WASHER-TOP LOADING
Maytag LAT8740AAL WASHER-TOP LOADING
Maytag LAT8740AAW WASHER-TOP LOADING
Maytag LAT8800AAL WASHER-TOP LOADING
Maytag LAT8800AAW WASHER-TOP LOADING
Maytag LAT8800ABL WASHER-TOP LOADING
Maytag LAT8800ABW WASHER-TOP LOADING
Maytag LAT8804AAE WASHER-TOP LOADING
Maytag LAT8804AAL WASHER-TOP LOADING
Maytag LAT8804AAM WASHER-TOP LOADING
Maytag LAT8804ABE WASHER-TOP LOADING
Maytag LAT8816AAE WASHER-TOP LOADING
Maytag LAT8816AAM WASHER-TOP LOADING
Maytag LAT8820AAL WASHER-TOP LOADING
Maytag LAT8820AAW WASHER-TOP LOADING
Maytag LAT8820ABL WASHER-TOP LOADING
Maytag LAT8820ABW WASHER-TOP LOADING
Maytag LAT8820BAL WASHER-TOP LOADING
Maytag LAT8820BAW WASHER-TOP LOADING
Maytag LAT8820BBL WASHER-TOP LOADING
Maytag LAT8820BBW WASHER-TOP LOADING
Maytag LAT8824AAE WASHER-TOP LOADING
Maytag LAT8824AAL WASHER-TOP LOADING
Maytag LAT8824AAM WASHER-TOP LOADING
Maytag LAT8824ABE WASHER-TOP LOADING
Maytag LAT8826AAE WASHER-TOP LOADING
Maytag LAT8826AAM WASHER-TOP LOADING
Maytag LAT8840AAL WASHER-TOP LOADING
Maytag LAT8840AAW WASHER-TOP LOADING
Maytag LAT8840ABL WASHER-TOP LOADING
Maytag LAT8840ABW WASHER-TOP LOADING
Maytag LAT8840BAL WASHER-TOP LOADING
Maytag LAT8840BAW WASHER-TOP LOADING
Maytag LAT8840BBL WASHER-TOP LOADING
Maytag LAT8840BBW WASHER-TOP LOADING
Maytag LAT8904AAE WASHER-TOP LOADING
Maytag LAT8904AAL WASHER-TOP LOADING
Maytag LAT8904AAM WASHER-TOP LOADING
Maytag LAT9200AAE WASHER-TOP LOADING
Maytag LAT9200AAG WASHER-TOP LOADING
Maytag LAT9200AAL WASHER-TOP LOADING
Maytag LAT9200AAM WASHER-TOP LOADING
Maytag LAT9200AAW WASHER-TOP LOADING
Maytag LAT9200ABE WASHER-TOP LOADING
Maytag LAT9200ABL WASHER-TOP LOADING
Maytag LAT9200ABM WASHER-TOP LOADING
Maytag LAT9200ABW WASHER-TOP LOADING
Maytag LAT9200BAE WASHER-TOP LOADING
Maytag LAT9200BAL WASHER-TOP LOADING
Maytag LAT9200BAM WASHER-TOP LOADING
Maytag LAT9200BAW WASHER-TOP LOADING
Maytag LAT9200BBE WASHER-TOP LOADING
Maytag LAT9200BBL WASHER-TOP LOADING
Maytag LAT9200BBM WASHER-TOP LOADING
Maytag LAT9200BBW WASHER-TOP LOADING
Maytag LAT9200DAL WASHER-TOP LOADING
Maytag LAT9200DAW WASHER-TOP LOADING
Maytag LAT9205AAE WASHER-TOP LOADING
Maytag LAT9205AAM WASHER-TOP LOADING
Admiral LAT9205GGE WASHER-TOP LOADING
Maytag LAT9206AAE WASHER-TOP LOADING
Maytag LAT9206AAM WASHER-TOP LOADING
Maytag LAT9206ABE WASHER-TOP LOADING
Maytag LAT9206ABM WASHER-TOP LOADING
Maytag LAT9206BAE WASHER-TOP LOADING
Maytag LAT9206BAM WASHER-TOP LOADING
Maytag LAT9206BAQ WASHER-TOP LOADING
Maytag LAT9206BBE WASHER-TOP LOADING
Maytag LAT9206BBM WASHER-TOP LOADING
Maytag LAT9235AAE WASHER-TOP LOADING
Maytag LAT9235AAM WASHER-TOP LOADING
Maytag LAT9280AAL WASHER-TOP LOADING
Maytag LAT9280AAW WASHER-TOP LOADING
Maytag LAT9280ABL WASHER-TOP LOADING
Maytag LAT9280ABW WASHER-TOP LOADING
Maytag LAT9300AAL WASHER-TOP LOADING
Maytag LAT9300AAW WASHER-TOP LOADING
Maytag LAT9300ABL WASHER-TOP LOADING
Maytag LAT9300ABW WASHER-TOP LOADING
Maytag LAT9304AAE WASHER-TOP LOADING
Maytag LAT9304AAL WASHER-TOP LOADING
Maytag LAT9304AAM WASHER-TOP LOADING
Maytag LAT9304ABE WASHER-TOP LOADING
Admiral LAT9304AGE WASHER-TOP LOADING
Admiral LAT9304AGL WASHER-TOP LOADING
Admiral LAT9304AGM WASHER-TOP LOADING
Admiral LAT9304BGE WASHER-TOP LOADING
Maytag LAT9304DAL WASHER-TOP LOADING
Maytag LAT9304DAM WASHER-TOP LOADING
Admiral LAT9304EGE WASHER-TOP LOADING
Admiral LAT9304GGE WASHER-TOP LOADING
Maytag LAT9306AAE WASHER-TOP LOADING
Maytag LAT9306AAM WASHER-TOP LOADING
Maytag LAT9306ABE WASHER-TOP LOADING
Admiral LAT9306AGE WASHER-TOP LOADING
Admiral LAT9306AKM WASHER-TOP LOADING
Admiral LAT9306AKQ WASHER-TOP LOADING
Admiral LAT9306BGE WASHER-TOP LOADING
Admiral LAT9306DAM WASHER-TOP LOADING
Admiral LAT9306DAQ WASHER-TOP LOADING
Admiral LAT9306EGE WASHER-TOP LOADING
Admiral LAT9306GGE WASHER-TOP LOADING
Maytag LAT9314AAE WASHER-TOP LOADING
Maytag LAT9314AAL WASHER-TOP LOADING
Maytag LAT9314AAM WASHER-TOP LOADING
Maytag LAT9314ABE WASHER-TOP LOADING
Maytag LAT9316AAE WASHER-TOP LOADING
Maytag LAT9316AAM WASHER-TOP LOADING
Maytag LAT9316ABE WASHER-TOP LOADING
Maytag LAT9316ABM WASHER-TOP LOADING
Maytag LAT9334AAE WASHER-TOP LOADING
Maytag LAT9334AAL WASHER-TOP LOADING
Maytag LAT9334AAM WASHER-TOP LOADING
Maytag LAT9334ABE WASHER-TOP LOADING
  #2 (permalink)
Old 08-17-2008, 06:42 PM
Senior Expert
APP Volunteer
iamigor5@yahoo.com is on a distinguished road
Default
first off if it were a bad switch you wouldnt be able to spin the water out my guess without being able to check with meter would be a timer we can eliminate the motor because it spins does it fill with water and just hum or is it dead on all wash cycles
  #3 (permalink)
Old 08-17-2008, 06:57 PM
Junior Member
Default
won't do anything at all except spin cycle - no fill, no agitate. If set to soak cycle, the little red light comes on, otherwise all is quiet. Belts OK, pulleys seem OK to rotate in both directions.
  #4 (permalink)
Old 08-17-2008, 07:05 PM
Senior Expert
APP Volunteer
Default
ok if it wont fill up can only be one of two things either you have a bad water valve or a bad timer it wont wash until it is full of water on the flip side it cant get water unless the valve is getting power from the timer if possible ohm out the water valve if its good id say the timer is your culprit
  #5 (permalink)
Old 08-17-2008, 07:26 PM
Junior Member
Default
OK, that makes sense! Looks like I have a project when I get home from work tomorrow night! Thanks a lot!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag top load washer tony lare Washer Repair 1 12-08-2009 04:09 PM
Maytag top load washer DLAWR Oven Repair (including Ranges and Cooktops) 0 11-25-2009 09:46 AM
Maytag Washer Top Load wapiwulo Washer Repair 1 09-26-2009 02:16 PM
Maytag Performa Washer Died CltGrl1377 Washer Repair 1 05-27-2009 06:20 PM
Maytag washer Died maddyg Dishwasher Repair 8 09-03-2008 09:14 AM
