Discuss
Maytag washer will no spin
 in
Washer Repair
Have a Maytag washer that will not spin. The agitator moves during the spin cycle but the drum will not
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag washer will no spin
  #1 (permalink)
Old 08-16-2008, 09:34 PM
Rakar Rakar is offline
Junior Member
Rakar is on a distinguished road
Default Maytag washer will no spin
Model Number: MAV9600EWW   Brand: Maytag   Age: 1 - 5 years
Have a Maytag washer that will not spin. The agitator moves during the spin cycle but the drum will not spin. Any ideas?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-16-2008, 09:58 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Does it drain properly?
Check if the belt is not worn out.
If there is nothing wrong then the transmission is probably gone bad.
Here are the break down diagrams for the Maytag washer Model MAV9600EWW
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 08-17-2008, 07:07 AM
Junior Member
Default
Yes it does drain and the belt looks good. Is this something that I should call the service man for is it a do it yourself job. I did notice that the drive motor has a range of movement. It pivots on the base is this normal?
  #4 (permalink)
Old 08-18-2008, 02:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Very possible the transmission is gone bad. If your washer is less than 10 years old then the transmission should be covered under the limited (parts only) manufacturer warranty.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag washer LAT9605 AAE won't spin nmurani Washer Repair 0 08-13-2008 11:27 AM
Maytag washer won't spin mmorse44 Washer Repair 5 08-07-2008 04:56 AM
Maytag washer clicking during spin cycle krock Washer Repair 0 06-24-2008 07:39 PM
Maytag washer will not spin Teddyk Washer Repair 3 06-20-2008 05:56 PM
Maytag (Ensignia)washer won't spin Myra Washer Repair 2 10-08-2007 08:29 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
