| » Whirpool Washer |
Model Number: LTE5243DQ0 Brand: Whirlpool Age: 5 - 10 years
Leaks drops through housing on the siphon inlet hose connection from siphon to hose near the clamp. No damage appears on the hose. The drop leakage is through the holes at the housing/siphon. Picture enclosed.
Not sure the cause of leakage. Ads By Google Related Models |
I used to see quite a few of these and usually it was hard water building up around the nozzle where the water is injected in. It caused water to spray in at an odd angle, splashing some out whenever it fills. Try cleaning it up and scraping away any hard water deposits you find. Hope that helps.
Remove the clamp and hose. Disassemble and clean.
| Display Modes | |
| whirpool washer | vecaz | Washer Repair | 3 | 05-10-2009 06:39 AM |
| Whirpool washer | richard mason | Washer Repair | 1 | 01-05-2009 06:18 PM |
| Whirpool Washer | oanh le | Dishwasher Repair | 1 | 12-15-2008 07:29 PM |
| Whirpool Washer | eno2220 | Washer Repair | 3 | 10-22-2008 09:40 PM |
| whirpool washer | Bennie | Washer Repair | 1 | 02-23-2008 09:10 AM |
