Discuss
Maytag SE1000 won't spin or drain
 in
Washer Repair
I have a Maytag SE1000 series 06 sn#114073 VN. A while back the motor would chatter before going into the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag SE1000 won't spin or drain
  #1 (permalink)
Old 08-15-2008, 11:26 PM
Junior Member
DNyq is on a distinguished road
Question Maytag SE1000 won't spin or drain
Model Number: SE1000   Brand: Maytag   Age: More than 10 years
I have a Maytag SE1000 series 06 sn#114073 VN. A while back the motor would chatter before going into the spin/drain cycle and we would smell hot electrical, after a few days or loads the machine stopped completely like the power was pulled. I replaced the Control Assembly (#15 on most part diagrams of “Front Panel & Control Group”) with a series 00 because I was not able to find a series 06 anyplace. The washer and dryer worked for about a month until the washer would not spin or drain. I replaced both belts (drive and pump), at that time I noticed that the motor would function if I pushed up on the pulley, I do not suggest this (it was by accident, I was desperate, got quite startled, and still have all fingers), with my wisdom I replaced my motor, once again with a series 00 because I could not find a series 06. I start the washer cycle and it fills up great, pauses as normal, and then agitates for 5-10 seconds stops and you can smell electrical. If I try to just use the spin cycle the motor works and pumps for 5-10 seconds stops and once again the electrical smell.
I have a manual that indicated the problem could be the motor reversing relay or the motor run relay. I have replaced both relays (waited for parts to ensure the wiring would be correct) and the situation is the same.
I have disconnected the drive belt and tried the spin cycle once more, and once again the motor worked for 5-10 seconds and then stopped. I have also tried to reset the panel by disconnecting the power for more than an hour with no change. This was suggested to me by a repairman.
What should I do, or replace or test now?
Related Models
Maytag SE1000 STACKED LAUNDRY- ELE
Maytag SE1000T Stacked Laundry - Ele
Maytag SE7800 STACKED LAUNDRY- ELE
Whirlpool SE950PEKW0 Range (gas)*
Whirlpool SE950PEKW1 Range (gas)*
Whirlpool SE950PEPW0 Range (gas)*
Whirlpool SE950PERW0 Range (gas)*
Whirlpool SE950PERW1 Range (gas)*
Whirlpool SE950PERW2 Range (gas)*
Whirlpool SE950PERW3 Range (gas)*
Whirlpool SE950PERW4 Range (gas)*
Whirlpool SE950PERW5 Range (gas)*
Whirlpool SE950PERW6 GAS RANGE
Whirlpool SE950PERW7 Range (gas)*
Whirlpool SE950PERW8 Range (gas)*
Whirlpool SE950PERW9 GAS RANGE
Whirlpool SE950PSKW0 Range (gas)*
Whirlpool SE950PSKW1 Range (gas)*
Whirlpool SE950PSPW0 Range (gas)*
Whirlpool SE953PEKT0 Range (gas)*
Whirlpool SE953PEKT1 Range (gas)*
Whirlpool SE953PSKT0 Range (gas)*
Whirlpool SE953PSKT1 Range (gas)*
Whirlpool SE960PEPW0 Range (gas)*
Whirlpool SE960PEPW1 Range (gas)*
Whirlpool SE960PEPW2 Range (gas)*
Whirlpool SE960PEPW3 Range (gas)*
Whirlpool SE960PEPW4 Range (gas)*
Whirlpool SE960PEPW5 Range (gas)*
Whirlpool SE960PEPW6 Range (gas)*
Whirlpool SE960PEYN3 Range (gas)*
Whirlpool SE960PEYW0 Range (gas)*
Whirlpool SE960PEYW1 Range (gas)*
Whirlpool SE960PEYW2 Range (gas)*
Whirlpool SE960PEYW3 Range (gas)*
Maytag SE9900 STACKED LAUNDRY- ELE
Roper SEC350XW0 Ranges, Electric*
Roper SEC350XX1 30" ELECTRIC RANGE CONTINUOUS CLEAN OVEN
Whirlpool SEDS800HQ0 ELECTRIC DRYER
Whirlpool SEDS800JQ0 DRYER
Whirlpool SEDS800JQ1 DRYER
Whirlpool SEDS800MQ0 29"ELECTRIC DRYER
Whirlpool SEDS800MQ1 29"ELECTRIC DRYER
Whirlpool SEDX600HQ0 ELECTRIC DRYER
Whirlpool SEDX600JQ0 ELECTRIC DRYER
Whirlpool SEDX600JQ1 ELECTRIC DRYER
Whirlpool SEDX600MQ0 29"ELECTRIC DRYER
Whirlpool SEDX600MQ1 29"ELECTRIC DRYER
Amana SEFS65D COMMERCIAL MICROWAVES
Jenn-Air SEG196 RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SEG196-C RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SEG196W RANGE-S/C S/I GAS & ELEC DUEL FUEL
Jenn-Air SEG196W-C RANGE-S/C S/I GAS & ELEC DUEL FUEL
Roper SEP340XX0 Ranges, Electric*
Whirlpool SEP340XX1 30" ELECTRIC RANGE STANDARD CLEAN OVEN
 SEQ7000FS0 DRYER
White Westinghouse SER341AQ0 Dryer - W.west
White Westinghouse SER341AQ1 Dryer - West/grupo Gomo
White Westinghouse SER341AQ2 White Westinghouse/electric Dryer
White Westinghouse SER341AS0 Dryer - W.west
White Westinghouse SER341AS1 Dryer - West/grupo Gomo
White Westinghouse SER341AS2 White Westinghouse/electric Dryer
General Electric SES0730DM1BB MICROWAVE
General Electric SES0730DM1WW MICROWAVE
General Electric SES0732DN1BB MICROWAVE
General Electric SES0732DN1WW MICROWAVE
General Electric SES0732DN2BB MICROWAVE
General Electric SES0732DN2WW MICROWAVE
Roper SES370XX0 ELECTRIC RANGE
Whirlpool SES374HQ0 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool SES374HQ1 ELECTRIC RANGE
Whirlpool SES380MS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool SF0100EKW0 Range (gas)*
Whirlpool SF0100EKW1 Range (gas)*
Whirlpool SF0100EKW2
Whirlpool SF0100ERW0 Range (gas)*
Whirlpool SF0100ERW1 Range (gas)*
Whirlpool SF0100ERW2 Range (gas)*
Whirlpool SF0100ERW3 Range (gas)*
Whirlpool SF0100ERW4 Range (gas)*
Whirlpool SF0100ERW5 Range (gas)*
Whirlpool SF0100ERW6 Range (gas)*
Whirlpool SF0100ERW7 Range (gas)*
Whirlpool SF0100ERW8 Range (gas)*
Whirlpool SF0100SKW0 Range (gas)*
Whirlpool SF0100SKW1 Range (gas)*
Whirlpool SF0100SRW0 Range (gas)*
Whirlpool SF0100SRW1 Range (gas)*
Whirlpool SF0100SRW2 Range (gas)*
Whirlpool SF0100SRW3 Range (gas)*
Whirlpool SF0100SRW4 Range (gas)*
Whirlpool SF0100SRW5 Range (gas)*
Whirlpool SF0100SRW6 Range (gas)*
Whirlpool SF0100SRW7 Range (gas)*
Whirlpool SF0100SRW8 Range (gas)*
Whirlpool SF0100SRW9 Range (gas)*
Whirlpool SF0100SYW0 Range (gas)*
Whirlpool SF0105EPW0 Range (gas)*
Whirlpool SF0105SPW0 Range (gas)*
Whirlpool SF010EERW0 Range (gas)*
Whirlpool SF010EERW1 Range (gas)*
Whirlpool SF010EERW2 Range (gas)*
Whirlpool SF010ESPW0 Range (gas)*
Whirlpool SF010ESRW0 Range (gas)*
Whirlpool SF010ESRW1 Range (gas)*
Whirlpool SF010ESRW2 Range (gas)*
Whirlpool SF0140SRW0 Range (gas)*
Whirlpool SF0140SRW1 Range (gas)*
Whirlpool SF0140SRW2 Range (gas)*
Whirlpool SF0140SRW3 Range (gas)*
Whirlpool SF0140SRW4 Range (gas)*
Whirlpool SF0140SRW5 Range (gas)*
Whirlpool SF0140SRW6 Range (gas)*
Whirlpool SF110AXSQ0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF110AXSQ1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF110AXSQ2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF111PXSQ0 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF111PXSQ1 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
Whirlpool SF111PXSQ2 30" GAS FREESTANDING STANDARD CLEAN RANGE ELECTRONIC IGNITION
  #2 (permalink)
Old 08-16-2008, 07:07 AM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
It's possible that the new motor could be defiective or the the "incident" you described damaged it. It sounds like you already have a lot tied up in this machine.
Are your tension springs tight on both belts? Have you checked the pump to make sure you have no obstuctions?
Just a few suggestions
Nat
  #3 (permalink)
Old 08-16-2008, 11:15 AM
Junior Member
Default Tension springs? Incident?
I'm not sure if you mean the springs that are located on the motor mount slide? If so they are fine, and there are not any others that I am aware of. When the drive belt is off the only belt connected is the one to the pump, therefore it is only opperating the pump and it does that just fine for about 5-10 seconds.
I am also not sure of the incdent that you are refering to.
Please
  #4 (permalink)
Old 08-16-2008, 11:33 AM
Senior Expert
APP Volunteer
Default
I was refering to the pushing up of the pulley.
What motor did you put on part number?
  #5 (permalink)
Old 08-16-2008, 11:58 AM
Junior Member
Default Washer does not drain
The motor I replaced was part # 4 on the "Motor and Pump Assembly" PDF. The springs I am refering to are located on part #13 same PDF. As to the incident I was just moving my hand under the machine to see if there was an obstructionor something and the back of my hand touched the pulley it started I got startled pulling my hand out. the motor moved about a 1/8" vertical. I don't believe that I should try to hold the motor up that 1/8" a friend of ours has the same unit and his motor also moves vertically (when stopped) 1/8"
  #6 (permalink)
Old 08-16-2008, 12:01 PM
Senior Expert
APP Volunteer
Default
Did you change part number 3 on the diagram?
  #7 (permalink)
Old 08-16-2008, 12:20 PM
Junior Member
Default
That part came with the motor (I think)
  #8 (permalink)
Old 08-16-2008, 12:25 PM
Senior Expert
APP Volunteer
Default
Ok,
Sounds like you have something in your pump causing a strain on the motor or possibly a defective new motor (which does happen) but I'd lean more to an obstruction or just bad pump.
Nat
  #9 (permalink)
Old 08-16-2008, 12:33 PM
Junior Member
Default
When it starts to spin it pumps out just fantastic. So it must be a bad pump, I guess.
Off to the Laundromat
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag SE1000 stack dryer motor removal Lynn Finch Dryer Repair 0 12-23-2009 01:06 PM
Maytag Atlantis won't drain or spin mhn1961 Washer Repair 1 08-24-2009 05:55 PM
Maytag Washer DOES NOT DRAIN/SPIN Modernm Washer Repair 0 04-20-2009 09:28 AM
Maytag SE1000 Motor switch DNyq Washer Repair 2 08-29-2008 06:34 AM
