Discuss
Washer motor spins but will not agitate.
 in
Washer Repair
Recently I washed a load of new towels and shortly afterwards the washer would not drain. I took the pump
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer motor spins but will not agitate.
  #1 (permalink)
Old 09-15-2007, 08:42 AM
jimmyr jimmyr is offline
Junior Member
jimmyr is on a distinguished road
Cool Washer motor spins but will not agitate.
Model Number: WNSR2100T2AA   Brand: GE   Age: More than 10 years
Recently I washed a load of new towels and shortly afterwards the washer would not drain. I took the pump apart and found it was clogged with lent from the towels. I removed the lent and the pump normally.
Shortly after that I noticed the agitator was not working through the wash cycle. Everything else seems to work fine.
Could the lent have affected the agitator?
What else could be the problem?
How is the agitator removed?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-19-2007, 05:34 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Wrap a rope around the bottom of the agitator and yank out the agitator.Check the plastic coupler for busted pieces. If ok you may have a bad belt.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't spin or agitate BH5977 Washer Repair 3 11-03-2007 03:56 PM
Washer motor hums, but won't drain, agitate or spin redwood646 Washer Repair 2 09-11-2007 08:39 PM
Amana washer won't agitate dsperlne Washer Repair 0 08-27-2007 04:00 PM
Washer won't agitate Jim Adkins Washer Repair 1 08-26-2007 03:01 PM
washer fills but won't agitate jamesamc Washer Repair 1 07-24-2007 03:42 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
