Discuss
Crosely won't agitate,over fills,but does spin
 in
Washer Repair
Hi! I have a Crosl ey Model#CW7000W-Here's the Prob~~When you turn it on,it starts filling up Ok,but it doesn't stop
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Crosely won't agitate,over fills,but does spin
  #1 (permalink)
Old 07-26-2010, 12:56 PM
Junior Member
stopped_at_4 is on a distinguished road
Exclamation Crosely won't agitate,over fills,but does spin
Model Number: CW7000W   Brand: Crosley   Age: More than 10 years
Hi! I have a Crosley Model#CW7000W-Here's the Prob~~When you turn it on,it starts filling up Ok,but it doesn't stop filling!It also won't agitate.It will however,spin. Help me Please-My clothes are pileing up!
Thank-You in advance!
Related Models
Crosley CW7000W WASHER-TOP LOADING
Crosley CW7500Q WASHER-TOP LOADING
Crosley CW7500W WASHER-TOP LOADING
Amana CW76T MWAVE- CNTRTP / STAND ALONE
Crosley CW8000A WASHER-TOP LOADING
Crosley CW8000W WASHER-TOP LOADING
Amana CW8202W2 WASHER-TOP LOADING
Amana CW8203W WASHER-TOP LOADING
Amana CW8203W2 WASHER-TOP LOADING
Amana CW8403W WASHER-TOP LOADING
Amana CW8413W2 WASHER-TOP LOADING
Crosley CW8500W WASHER-TOP LOADING
Amana CW9003 WASHER-TOP LOADING
Amana CW9003W WASHER-TOP LOADING
Amana CW9203W WASHER-TOP LOADING
Amana CW9203W2 WASHER-TOP LOADING
Amana CW9203W3 WASHER-TOP LOADING
Crosley CW9500W WASHER-TOP LOADING
Crosley CW9505W WASHER-TOP LOADING
Maytag CWE1000 WALLOVEN- S/C ELE
Maytag CWE400 WALLOVEN- STD ELE
Maytag CWE401 WALLOVEN- STD ELE
Maytag CWE402 WALLOVEN- STD ELE
Maytag CWE4020ACB WALLOVEN- STD ELE
Maytag CWE4020BCB WALLOVEN- STD ELE
Maytag CWE4100ACB10 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4100ACE10 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4200ACB WALLOVEN- STD ELE
Maytag CWE450 WALLOVEN- STD ELE
Maytag CWE451 WALLOVEN- STD ELE
Maytag CWE470 WALLOVEN- S/C ELE
Maytag CWE4700ACB WALLOVEN- S/C ELE
Maytag CWE4700ACE WALLOVEN- S/C ELE
Maytag CWE4700BCB WALLOVEN- S/C ELE
Maytag CWE4700BCE WALLOVEN- S/C ELE
Maytag CWE4800ACB WALLOVEN- S/C ELE
Maytag CWE4800ACB25 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4800ACE WALLOVEN- S/C ELE
Maytag CWE4800ACE27 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4800ACS WALLOVEN- S/C ELE
Maytag CWE4800ACS14 24" BUILT-IN ELECTRIC OVEN
Maytag CWE500 WALLOVEN- STD ELE
Maytag CWE501 WALLOVEN- STD ELE
Maytag CWE502 WALLOVEN- STD ELE
Maytag CWE5020ACB WALLOVEN- STD ELE
Maytag CWE5020BCB WALLOVEN- STD ELE
Maytag CWE5100ACB10 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5200ACB WALLOVEN- S/C ELE
Maytag CWE550 WALLOVEN- S/C ELE
Maytag CWE5500ACB WALLOVEN- S/C ELE
Maytag CWE5500ACE WALLOVEN- S/C ELE
Maytag CWE5500BCB WALLOVEN- S/C ELE
Maytag CWE5500BCE WALLOVEN- S/C ELE
Maytag CWE5800ACB WALLOVEN- S/C ELE
Maytag CWE5800ACB25 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5800ACE WALLOVEN- S/C ELE
Maytag CWE5800ACE28 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5800ACS WALLOVEN- S/C ELE
Maytag CWE5800ACS14 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE600 WALLOVEN- S/C ELE
Maytag CWE601 WALLOVEN- S/C ELE
Maytag CWE602 WALLOVEN- S/C ELE
Maytag CWE6020ACB WALLOVEN- S/C ELE
Maytag CWE6200ACB WALLOVEN- S/C ELE
Maytag CWE6200ACE WALLOVEN- S/C ELE
Maytag CWE6200ADB WALLOVEN- S/C ELE
Maytag CWE6200ADE WALLOVEN- S/C ELE
Maytag CWE6230ACB WALLOVEN- S/C ELE
Maytag CWE6230ACE WALLOVEN- S/C ELE
Maytag CWE6230ADB WALLOVEN- S/C ELE
Maytag CWE6230ADE WALLOVEN- S/C ELE
Maytag CWE6800ACB WALLOVEN- S/C ELE
Maytag CWE6800ACE WALLOVEN- S/C ELE
Maytag CWE6830ACB WALLOVEN- S/C ELE
Maytag CWE6830ACE WALLOVEN- S/C ELE
Maytag CWE700 WALLOVEN- S/C ELE
Maytag CWE7000ACB WALLOVEN- S/C ELE
Maytag CWE7000ACE WALLOVEN- S/C ELE
Maytag CWE701 WALLOVEN- S/C ELE
Maytag CWE7800ACB WALLOVEN- S/C ELE
Maytag CWE7800ACE WALLOVEN- S/C ELE
Maytag CWE7830ACB WALLOVEN- S/C ELE
Maytag CWE7830ACE WALLOVEN- S/C ELE
Maytag CWE900 WALLOVEN- S/C ELE
Maytag CWE9000ACB WALLOVEN- S/C ELE
Maytag CWE9000ACE WALLOVEN- S/C ELE
Maytag CWE9000BCB WALLOVEN- S/C ELE
Maytag CWE9000BCE WALLOVEN- S/C ELE
Maytag CWE9000BCM WALLOVEN- S/C ELE
Maytag CWE9000BDB WALLOVEN- S/C ELE
Maytag CWE9000BDE WALLOVEN- S/C ELE
Maytag CWE9000CDB WALLOVEN- S/C ELE
Maytag CWE9000CDE WALLOVEN- S/C ELE
Maytag CWE9000DDB WALLOVEN- S/C ELE
Maytag CWE9000DDE WALLOVEN- S/C ELE
Maytag CWE9030BCB WALLOVEN- S/C ELE
Maytag CWE9030BCE WALLOVEN- S/C ELE
Maytag CWE9030BDB WALLOVEN- S/C ELE
Maytag CWE9030BDE WALLOVEN- S/C ELE
Maytag CWE9030DDB WALLOVEN- S/C ELE
Maytag CWE9030DDE WALLOVEN- S/C ELE
Maytag CWE9900 WALLOVEN- S/C ELE
Admiral CWEA100ACB WALLOVEN- STD ELE
White Westinghouse CWEF309ES1 White Westinghouse/electric Range
White Westinghouse CWEF310ES1 White Westinghouse Canada/electric Range
White Westinghouse CWEF310FSA Ww Canada/electric Range
White Westinghouse CWEF310GSA ELECTRIC RANGE
White Westinghouse CWEF310GSB ELECTRIC RANGE
White Westinghouse CWEF310GSC ELECTRIC RANGE
White Westinghouse CWEF310GSD ELECTRIC RANGE
  #2 (permalink)
Old 07-26-2010, 02:22 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
You, probably have a clog,kink or hole, in the air dome hose which attaches to your water level switch and right rear area of the outer tub(you will need to raise the top of the mchine to access and trace the hose.
Part number: AP4025726
You could also have an inoperative water level switch, ( the hose is more likely)you would have to access the interior of the control panel.
Part number: AP4025680
Any one of these two components that fail would cause your machine to overfill and not start the agitate cycle.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Washer fills/drains but won't spin/agitate sierrapup Washer Repair 2 11-19-2015 06:03 PM
maytag fills doesn't agitate spin etc vanlisa Washer Repair 3 12-28-2010 12:57 PM
GE washer -fills & Drains, but will not spin or agitate tmacky34 Washer Repair 0 03-20-2010 05:54 AM
GE fills and drains but doesn't agitate or spin ladytech Washer Repair 0 02-13-2009 02:11 PM
Washer fills up but won't agitate or spin michose Washer Repair 1 08-11-2008 02:54 AM
