Discuss
Control Panel Touch Pad not working
 in
Washer Repair
Hey there folks, I have a Whirlpool Calypso washer and the other day the touch pad of the control panel
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Control Panel Touch Pad not working
  #1 (permalink)
Old 09-14-2007, 03:02 PM
rtismeer rtismeer is offline
Junior Member
rtismeer is on a distinguished road
Default Control Panel Touch Pad not working
Model Number: GVW9959KQ2   Brand: Whirlpool   Age: 1 - 5 years
Hey there folks,
I have a Whirlpool Calypso washer and the other day the touch pad of the control panel decided to stop working i.e., pressing any button doesn't light up the option chosen.
First I checked the breakers .... they were fine.
Then I pulled out the volt meter and checked the outlet .... that gave power.
Then I opened the back of the control panel and tested the voltage going into the Machine Control Board .... that had 120V as well!
So I followed the lines going from the Machine Control Board to the Motor Control Board and expected it to get 120V as well, but that wasn't the case .... thus my rookie answer was that the Machine Control Board must have a broken electronic part on it so it's not forwarding power to the Motor Control Board (based on my results, I was probably wrong).
Hence I bought a new Machine Control Board and just replaced it expecting (/hoping) for the machine to work .... DOH! no dice, it still doesn't work.
Now I hope to gain some experience from you experts out there on what I should do next?
Here's the diagram page for my machine:
Model GVW9959KQ2
I didn't happen to notice an in-line fuse, and the lid switch being open or closed doesn't have an effect on the dryer, thus I assume it wouldn't have one on the washer either.
Please help :-) Laundry for 5 is piling up.
Thanks in advance,
Roger
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-17-2007, 07:21 AM
rivera rivera is offline
Junior Member
rivera is on a distinguished road
Default
Hi Roger,
I have the same problem with my Whirlpool Calypso GVW9959KQ2. Did you get a response from the repair guru's on how to fix this problem. Is the problem the Electronic Control Board, the Motor Control Board or the Touch pad?? Please.. your immediate response is requested.
Thanks,
Rivera
  #3 (permalink)
Old 10-17-2007, 03:11 PM
Junior Member
Default
Hi rivera,
After originally ordering the Electronic Control Board (ECB), which did not fix the matters ... I then consulted a local repair shop (recommended by whirlpool.com) and they stated it was the actual Control Panel Assembly and that I blew a fuse on my Motor Control Board.
They ordered both parts for me, but after 2 weeks of waiting, they claimed they received the Motor Control Board (MCB), but that the Control Panel Assembly was on backorder indefinitely!
My response to that was BS, because a manufacturer needs to produce parts for discontinued equipment for 7 years after being discontinued.
I opted to purchase and replace the parts myself, thus I bought the Motor Control Board and Control Panel Assembly (CPA) ... side note on the CPA, I ordered the "pewter" color when I actually have the "pearl" shade in the laundry room [pearl apparently is the indefinte backorder color]. Personally I didn't care that there was a slight (I mean very minimal) color difference at all ... and now after having it installed, I actually like the pewter one better than the pearl!
Anyways, to get back on subject here, once I received the MCB and CPA (33 days after my original ECB purchase) .... I only installed the CPA with the old ECB & MCB and it worked like a charm! It's been 4 days now since install of the CPA and it's doing wonderful :-) Now the task is to wash, wash, and wash for my family of 5!
I hope this happens to be your issue as well and is thus easily resolvable.
Good luck,
Roger
  #4 (permalink)
Old 10-18-2007, 10:46 AM
Willie Mays Willie Mays is offline
Junior Member
Willie Mays is on a distinguished road
Default
Quote:
Originally Posted by rtismeer View Post
Hey there folks,
Model GVW9959KQ2
Thanks in advance,
Roger
Thanks for sharing your experience. I have the Calypso GVW9959KL1. I suspect it is the same part that failed, the CPA, even though I have power on the panel (it is stuck on 8 minutes remaining). No matter how many times I press the cancel button, the remaining time is 8 minutes and the other buttons are non-responsive. I opened the panel and checked and could not find any lose connections. My questions are:
o Where did you purchase the part? Online?
o What manual did you use?
TIA
  #5 (permalink)
Old 10-19-2007, 08:04 AM
Junior Member
Default
Hey Willie,
I purchased the part from Appliance Parts Pros.com Discount Appliance Parts – Appliance Repair Parts
Just type in your ..KL1 model # (or the following link: Model GVW9959KL1)
Select the Control Panel Diagram (#4) in the top-left frame, look at the rendition in the top-right frame, notice the Control Panel is #9, and then scroll down the bottom-right frame to view the spec on that part number .... process the order from there.
Oh as far as the manual is concerned .... don't have one, it's just a matter of unscrewing some nuts & bolts and unplugging some of the electrical cable connectors.
Good luck!
Roger
  #6 (permalink)
Old 09-06-2008, 06:39 PM
gldavis gldavis is offline
Junior Member
gldavis is on a distinguished road
Default
Quote:
Originally Posted by rivera View Post
Hi Roger,
Thanks,
Rivera
Rivera, what did you wind up doing? My GVW9959KQ2 is having the same problem (no led lights or sounds). Per Roger's experience I should replace the touchpad, but all the Whirlpool documentation indicates to replace the ECB first. I'd feel better about just ording the touchpad if I had an additional data point. BTW, big thanks to Roger for such a helpful post.
Please help! Thanks in advance.
Greg
  #7 (permalink)
Old 09-08-2008, 11:30 AM
Junior Member
Default
Thanks for the attaboy gldavis :-)
It's been what, almost a year now .... the washing machine is still plugging away!
Very happy DIYer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replacing oven control panel brad Oven Repair (including Ranges and Cooktops) 2 07-14-2008 03:55 PM
Control panel in fridge does not display BobD Refrigerator & Freezer Repair 1 06-08-2008 05:11 AM
Do I have a bad control panel? wenoch01 Oven Repair (including Ranges and Cooktops) 4 11-05-2007 05:51 PM
Dryer Control Panel Dead! Corel Dryer Repair 1 08-10-2007 09:47 PM
Replacing Control Panel bhandg Oven Repair (including Ranges and Cooktops) 2 07-23-2007 05:30 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
