Discuss
Replaced pump now motor wont go
 in
Washer Repair
Earlier this week the washing machine was making some noise everytime the motor would turn on. There was a slight
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Replaced pump now motor wont go
  #1 (permalink)
Old 08-14-2008, 06:23 AM
jzawacki jzawacki is offline
Junior Member
jzawacki is on a distinguished road
Exclamation Replaced pump now motor wont go
Model Number: LW8203W2   Brand: Maytag   Age: More than 10 years
Earlier this week the washing machine was making some noise everytime the motor would turn on. There was a slight burning smell and it my wife says it was shutting off.
I unplugged the unit, opened the front panel and found that there was some water around the lip on the top of the pump. I also noticed the belt was extremely worn and cracked. Without any laundry in, I cycled the machine to see if I could identify if the leak was purely the pump or something else. The machine ran fine and I could not see any leaks at all while running. I did notice that the motor seemed to labor a bit to get started (ie. it makes a pretty loud moan as it starts).
Based on these observations, I ordered the pump and belt and replaced those last night. When putting the new pump on to the bottom of the motor shaft that it was a little difficult to turn the pump to align it with the shaft before pressing it on.
When I went to cycle the machine, the motor will not go at all. I just moans loudly (obviously, I only let it do that for a split second not wanting to burn it out). With the machine unplugged, I tried spinning the drive pulley and it is very difficult (couldn't move it much with my fingers, I needed plyers). I don't hear/feel any grinding when I do get it so move.
I am wondering if the new pump is bad. Should it have been very easy to spin right out of the box?
or
Is the motor bad? I would think a 1/2 horsepower motor would have plenty of power to spin that pump even if it was a little tight. Is there a way to test/verify that?
Any help would be greatly appreciated before I go spending close to $200 on a motor.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-14-2008, 07:11 AM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
HI
If you have an ohm meter you may want to check the motor switch on top of the motor, Those tend to go out and are a lot cheaper than a motor.
  #3 (permalink)
Old 08-14-2008, 07:23 AM
Junior Member
Default
I do have an ohm meter. Do you know how or where I can find instruction on how to check that?
  #4 (permalink)
Old 08-15-2008, 11:45 AM
Senior Expert
APP Volunteer
Default
You may want to double check your connections to make sure everything is getting good contact.
If you decide to check the motor switch, unplug the conntector and check for continuity to the switch. If there is continuity then test the motor itself.
Let me know what you find.
  #5 (permalink)
Old 08-15-2008, 05:20 PM
Junior Member
Default
I took it all appart again. I completely removed the motor. I can spin it by hand by grabbing the pulley and turning it but it stops as soon as I stop pushing (it won't continue at all on its own).
I checked with and ohm meter all the different contacts. I am not sure what I'm looking for though. The brown and red wires have continuity to each other and the last pin on the connector. The other wires in between the brown and red have continuity to the white wire. Is that how it should be?
How can I test the motor?
  #6 (permalink)
Old 08-15-2008, 08:13 PM
Senior Expert
APP Volunteer
Default
With the motor out, if you can't spin the shaft and it keep spinning then unfortuneately the motor is shot. part #AP3672573
That was probably shot when it started groaning in the first place, which may have locked up and what made the pump leak a little.
Hope that helps you a little.
Nat
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Drain pump replaced, now timer stops after wash and will not rinse BeardedDan Washer Repair 1 06-13-2008 12:05 PM
replaced igniter in dryer and wont heat up to ignite gas gordhau Dryer Repair 3 05-24-2008 10:33 AM
Replaced Chopper - Is Pump OK? crtwood Dishwasher Repair 1 03-22-2008 04:34 PM
Lights wont lite up after being replaced abovepc Microwave Repair 6 01-25-2008 09:21 AM
Replaced Motor and now it doesn't clean Hot-Point Dishwasher Repair 0 11-15-2007 05:55 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
