The Bosh is no longer letting hot or warm water into the system. It started with the hot and thought maybe the water was too hot coming in. Turned down the hot water worked for about 2 loads then nothing. Was able to use warm water then that stopped. Can only wash in cold. I was thinking that it was the magnet valve(hot valve). Could it be something else. When we select hot water no water comes in.:confused:
