Discuss
Inner tub removal
 in
Washer Repair
I suspect the spin bearing is defective in my washer. It makes a loud noise during it's spin cycle.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Inner tub removal
  #1 (permalink)
Old 08-13-2008, 02:14 PM
danceilike danceilike is offline
Junior Member
danceilike is on a distinguished road
Default Inner tub removal
Model Number: MAV5000AWQ   Brand: Maytag   Age: 5 - 10 years
I'm attempting to remove the inner tub---have the agitator out, the 4 bolts out, but the tub won't release from it's base. Could the problem be sealant on the gasket? Is there a simple way to break loose the tub? I don't to use force and damage something.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-14-2008, 04:59 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If you hold the spin basket during spin and it still makes bearing noises, you have a bad tranny.
The tub has a ball bearing supporting the tub. Lots of times the seal for this will leak and you can see dirty water marks on the seal area where the tranny goes into the tub.
I would soak the spin basket hub with penetrating oil. The hub tends to rust to the spin basket on these washers.
For specific info, go to web site www.applianceaid.com
__________________
  #3 (permalink)
Old 08-14-2008, 05:33 AM
Junior Member
Post Inner Tub Removal
Thanks, richappy,
I applied penetrating oil to the hub area last night. Will try to remove the tub this morning. I believe the tranny is okay. Will know as soon as I remove the tub. Not sure if a clip or pin is securing the tub now that the 4 bolts have been removed. What is the best way to break loose the tub after applying penetrating oil to it? Don't want to cause additional damage.
Thanks again,
Ken
  #4 (permalink)
Old 08-14-2008, 02:27 PM
Senior Expert
APP Volunteer
Default
I can only refer you to the mentioned web site, have never done this job before.
__________________
  #5 (permalink)
Old 08-15-2008, 05:22 AM
Junior Member
Default Inner Tub Removal
Thanks again, richappy.
Checked out the site you referenced. It told me all I need to know re the washer.
Ken
  #6 (permalink)
Old 08-22-2008, 06:03 PM
Junior Member
Finally got the tub to break loose from it's mounting base after soaking the area with prnrtrating oil and then placing a short section of 2 x 4 lumber beneath the lib of the tub ann tapping it with a hammer. The tub was stuck to the gasket. Now I'm having problems removing the seal nut and spin bearing nut. Anybody know which direction they rotate? CW or CCW looking from the top of the washer?
Thanks, Ken
  #7 (permalink)
Old 08-23-2008, 05:02 AM
Senior Expert
APP Volunteer
Default
All Maytags I have seen have a left hand thread for the tub nut, turn counterclockwise to remove.
__________________
  #8 (permalink)
Old 08-23-2008, 06:03 AM
Junior Member
Thanks, richappy.
It's a tough one to remove. Wanted to make sure I'm turning it the correct direction.
Ken
  #9 (permalink)
Old 08-26-2008, 11:50 AM
Junior Member
Thanks for all the help, richappy,
Finally got the seal nut off. It's plastic---cut it off with a sharp chisel. Now I'm trying to remove the bearing nut. It's the one the unner tub mounts on and is metal. I'm using a spanner wrench, tapping it lightly, but it won't break loose. My problem--the whole shaft moves. I'm trying to figure out a way to hold the shaft. I suppose I need someone to hold the bottom pulley while I tap the spanner wrench. Any ideas?
Thanks---Ken
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tub Removal zpdd03 Washer Repair 0 07-05-2008 10:17 AM
Control Box Removal EDB Refrigerator & Freezer Repair 4 06-13-2008 06:47 AM
clutch removal thelazydentist Washer Repair 1 12-04-2007 01:15 AM
Grille Removal Libbilu Refrigerator & Freezer Repair 1 11-27-2007 06:19 PM
Transmission Removal Street777 Washer Repair 0 08-01-2007 05:57 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
