Discuss
Washer does not work in gentle cycle
 in
Washer Repair
When selecting the gentle setting the washer will fill with water but will not cycle through. The spin cycle will
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer does not work in gentle cycle
  #1 (permalink)
Old 09-14-2007, 11:13 AM
hcjr hcjr is offline
Junior Member
hcjr is on a distinguished road
Default Washer does not work in gentle cycle
Model Number: LA7800XS   Brand: Whirlpool   Age: More than 10 years
When selecting the gentle setting the washer will fill with water but will not cycle through. The spin cycle will not work. With the other settings the spin cycle works but my wife thinks the spin cycle even on these other settings isn't removing quite as much water as it previously did. Any help would be greatly appreciated. Thanks to all in advance.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-15-2007, 03:58 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Does the motor stop, and refuse to start again on these normal cycles. If so you probably have a bad timer.
Also, check the motor socket pins, push in the low speed wire pin and see if it now works, sometimes they become loose.
__________________
  #3 (permalink)
Old 09-15-2007, 09:35 AM
Junior Member
Default
Thanks for the advice. No, the motor does not stop and refuse to start again in the normal cycles. I assume the motor socket pins are by the motor and that I need to remove the cabinet. Is that correct? I've tried to look at the schematics on repairave.com but can't locate the motor socket pins. Are they sometimes referred to by another name?
  #5 (permalink)
Old 09-16-2007, 06:51 PM
Junior Member
Default
Thanks again for the help. I did go to the suggested website and searched but still could not find "motor socket pins". Are you referring to the electrical connections, wire leads? At the motor? At the timer? Would appreciate any additional help you or anyone else is willing to share. Thanks.
  #6 (permalink)
Old 09-17-2007, 03:28 AM
Senior Expert
APP Volunteer
Default
The connector is mounted on the side of the compressor. I usually test with power on, just push in on the pins, it will start up if that is your problem. For parts, just click on the appliancepartspros link above.
__________________
  #7 (permalink)
Old 09-21-2007, 01:25 PM
Junior Member
Default
I'm still confused. You mentioned the compressor in your posting. I've checked the website and can't find any compressor. Is there another name for what you call the compressor?
  #8 (permalink)
Old 09-22-2007, 05:24 PM
Senior Expert
APP Volunteer
Default
I meant to say motor. Sometimes the pins on the connector work loose.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer keeps repeating the rinse cycle hiltonacres Washer Repair 2 12-13-2007 08:22 PM
No spin on regular cycle, others work klawson Washer Repair 2 12-05-2007 03:58 PM
washer only works in delicate cycle ric Washer Repair 3 09-16-2007 03:25 AM
washer will not cycle mahat Washer Repair 1 09-02-2007 07:10 PM
washer overfills on super cycle only tawas Washer Repair 1 08-07-2007 09:19 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
