Discuss
bearing for Duet
 in
Washer Repair
just curious if anyone found a source for Duet Sport rear bearings? I need to replace mine and would rather
Appliance Repair Forum > Appliance Repair Help > Washer Repair » bearing for Duet
  #11 (permalink)
Old 11-04-2010, 06:31 PM
Junior Member
Truspark is on a distinguished road
Default
just curious if anyone found a source for Duet Sport rear bearings? I need to replace mine and would rather not have to buy the entire half a tub for $200. I read that you could probably bring the old bearing to a appliance parts store and they can match it up, has anyone had any success with that?
  #12 (permalink)
Old 11-07-2010, 05:21 PM
Junior Member
JoeMc is on a distinguished road
Default
Quote:
According to a search I did on google, the bearings for the Duet Model GHW9400 are made by NTN and are: rear - 6206LLBC3/5K & front -
6307LLBC3/L627. I have not been able to find a part number for the seal.
I don't know if the Duet Sport you mention would use the same bearing kit.
There is a fellow named Jeff Hartman who is advertising that he supplies a bearing kit (bearings plus seal) for Duet FL washers. see "duetbearing.com",WHIRLPOOL DUET BEARING AND SEAL KIT[. I have not been able to find any user feedback on his kits for the Duet or equivalent Elite washers. Maybe he can point you to some.
  #13 (permalink)
Old 11-12-2010, 10:43 AM
Junior Member
BDA123 is on a distinguished road
Default Bearing Replacement
Did you have any luck finding the seal kit? I haven't taken my Duet HT apart yet but mine is just starting to have problems. Pretty sure the basket is still in good shape and that the bearings are just starting to wear out. I read in several places that the bearing are molded into the rear tub. Have you already completed this repair and how hard was it? I am not worried about taking the unit apart, just about how difficult it will be to switch out the bearings in the outer tub.
  #14 (permalink)
Old 11-12-2010, 01:00 PM
Junior Member
Default
Quote:
It turned out my bearing and seal were fine, but the spider was totally destroyed. All 3 arms corroded thru and broken off at the hub. The Duet bearing and seal kit advertised does not have a removal tool available like the Neptune and costs about $80. A new rear outer tub costs about $200. Jeff Hartman would not confirm that his seal was the same as the original seal. It may be as good or better, but I could not get any further info. Anyhow, I did not need it and was not looking forward to replacing the bearings without the right tools. If you learn more, please let me know for future anticipated problems.
  #15 (permalink)
Old 11-12-2010, 01:15 PM
Junior Member
Default
Did you ever complete your replacement of the bearing/seal?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How do I tell if the Bearing is bad VickiS Dryer Repair 5 08-14-2009 08:24 AM
bearing kit the pit Washer Repair 2 07-15-2009 08:53 PM
Possible bad bearing porgas Washer Repair 1 06-24-2009 10:44 AM
whirlpool duet - bearing gone code override? trs123 Washer Repair 3 03-17-2008 01:57 PM
Duet Bearing Repair mt813 Washer Repair 2 03-12-2008 06:25 PM
