I have a mist like leak under my washer, When my washer is working,I put my hand under and feel a mist of water around and around the washer I would like to know where it's coming from Thanks.
Originally Posted by: gr8m I have a mist like leak under my washer, When my washer is working,I put my hand under and feel a mist of water around and around the washer I would like to know where it's coming from Thanks. Your water leak, based on the information you supplied, is possibly due to the following. A loose fitting or hole in the drain hose(s). A leaking seal in the drain pump. A leaking tub seal tub bearing assemblies. You will need to remove the front panel from the cabinet assembly to trace or observe where the leak is coming from.
