Getting a humming noise when machine is operating, all else is operating ok during cycle, checked the amperage for the motor, it's not over amping, not sure if what is causing the high pitch humming sound?
Sincerely,
Getting married next month & i'm broke
What current level did you measure. Also, is the sound "normal" in the high speed setting?
hey thanks for reply, found what was making the loud noise, motor rated at 9.6, drawing 8.2, disconnected the pump from the direct drive, noise went away, took it off and put back on several times just to make sure. Thank you
The smoke/burnout level for that motor is 10 amps! What does it draw when the pump is installed?
