AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Only Hot Water -replaced temp control board, worked once
Have been only getting Hot water on any temp setting. I replaced the analog temp control board and it worked when i tested cold setting. But a couple hours later I started a load and only hot again.
What would burn out the temp control board like that?
Locate the thermistor on the water inlet valve (the black nozzle with the two terminals) and remove the wires. If the terminals are corroded, replace the water inlet valve. You can check the thermistor by measuring its resistance. Depends on the temperature it suppose to be between 10 Kohms to 100 Kohms. - The water inlet valve Part number: AP4027562
Thanks Gene! Am I correct in assuming that the Alog Temp control board is burnt and will need replacing again?
I really appreciate your help TO
There is a 50/50 chance. I would replace the water inlet valve first.
Washer Repair
