My maytag Neptune washing machine displays the LR message when ever i start the spin cycle it will start to spin and then try to start again for about 4 times then displays the message ,,,,it is:confused: :confused: on level ground but it seems like the drum is off kilter on the inside and shakes bad ,,,and when ever it does this it shuts down with that code ,,,,, what could be wrong and what can i do to fix this ? any help would be greatly appreciated .
