I'm having trouble with my Frigidaire front load washer. It will run water into the tub and it will drain the water from the tub, but the tub won't spin at all. Model number LTF530DS1 Serial number XC53316483. My brother talked to a man who said the breaks may be locking up on it to hit the bolt in the back with a hammer. We did and it started spinning again, but only for a day then stopped again. We tried that again, but it's not working this time around. I've done a web search looking for a parts diagram to see where the breaks actually are with no results. Can someone help me figure out how to make the breaks stop locking up so my tub will spin please. Or is it something else causing this problem? Any suggestions would be greatly appreciated by this single mom.
