Discuss
Duet belt / drum drive play
 in
Washer Repair
Teenager overloaded the washer causing 2 of the shock absorbers to break/come free, eventually causing the belt to come off.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Duet belt / drum drive play
  #1 (permalink)
Old 07-18-2010, 04:26 PM
Junior Member
bmike is on a distinguished road
Default Duet belt / drum drive play
Model Number: GHW9200LW0   Brand: Whirlpool   Age: 5 - 10 years
Teenager overloaded the washer causing 2 of the shock absorbers to break/come free, eventually causing the belt to come off. I had planned to replace the shocks so I had them and changed all of them out; as a tip to anyone who wants to do this, make sure the replacement is orientated correctly and twist in the bottom first. Anyway after replacing them I put the belt back on but when hand turning it would wander off, it is pretty worn and a new one is on order, thanks AppliancePartsPros.com. My question is about the Drum Drive pulley, it seems to have a lot of play in and out on the rim, is this normal? Is the Drum Drive a wear part, should I replace it also? The nut that holds it on only gets so tight, I guess it is meant to move freely, to a point, on its axis. That darn nut was tight also, I had to get the air impact gun out to get it free. Thanks for your help!
Ads By Google
Related Models
Whirlpool GHW9200LW0
Whirlpool GHW9250ML0 Automatic Washer
Whirlpool GHW9250ML1 Automatic Washer
Whirlpool GHW9250ML2 Automatic Washer
Whirlpool GHW9250MQ0 Automatic Washer
Whirlpool GHW9250MQ1 Automatic Washer
Whirlpool GHW9250MQ2 Automatic Washer
Whirlpool GHW9250MT0 Automatic Washer
Whirlpool GHW9250MT1 Automatic Washer
Whirlpool GHW9250MT2 Automatic Washer
Whirlpool GHW9250MW0 Automatic Washer
Whirlpool GHW9250MW1 Automatic Washer
Whirlpool GHW9250MW2 Automatic Washer
Whirlpool GHW9300PW0 Automatic Washer
Whirlpool GHW9300PW1 Automatic Washer
Whirlpool GHW9300PW2 Automatic Washer
Whirlpool GHW9300PW3 Automatic Washer
Whirlpool GHW9300PW4 Automatic Washer
Whirlpool GHW9400PL0 Automatic Washer
Whirlpool GHW9400PL1 Automatic Washer
Whirlpool GHW9400PL2 Automatic Washer
Whirlpool GHW9400PL3 Automatic Washer
Whirlpool GHW9400PL4 Automatic Washer
Whirlpool GHW9400PT0 Automatic Washer
Whirlpool GHW9400PT1 Automatic Washer
Whirlpool GHW9400PT2 Automatic Washer
Whirlpool GHW9400PT3 Automatic Washer
Whirlpool GHW9400PT4 Automatic Washer
Whirlpool GHW9400PW0 Automatic Washer
Whirlpool GHW9400PW1 Automatic Washer
Whirlpool GHW9400PW2 Automatic Washer
Whirlpool GHW9400PW3 Automatic Washer
Whirlpool GHW9400PW4 Automatic Washer
Whirlpool GHW9400SU0 Automatic Washer
Whirlpool GHW9460PL0 Automatic Washer
Whirlpool GHW9460PL1 Automatic Washer
Whirlpool GHW9460PL2 Automatic Washer
Whirlpool GHW9460PL3 Automatic Washer
Whirlpool GHW9460PL4 Automatic Washer
Whirlpool GHW9460PW0 Automatic Washer
Whirlpool GHW9460PW1 Automatic Washer
Whirlpool GHW9460PW2 Automatic Washer
Whirlpool GHW9460PW3 Automatic Washer
Whirlpool GHW9460PW4 Automatic Washer
Whirlpool GHWT160JXX0
Whirlpool GI1500PHB0
Whirlpool GI1500PHB3
Whirlpool GI1500PHB4 Ice Cube Maker
Whirlpool GI1500PHB5 Ice Cube Maker
Whirlpool GI1500PHB6 Ice Cube Maker
Whirlpool GI1500PHB7 Ice Cube Maker
Whirlpool GI1500PHB8 Ice Cube Maker
Whirlpool GI1500PHW0
Whirlpool GI1500PHW3
Whirlpool GI1500PHW4 Ice Cube Maker
Whirlpool GI1500PHW5 Ice Cube Maker
Whirlpool GI1500PHW6 Ice Cube Maker
Whirlpool GI1500PHW7 Ice Cube Maker
Whirlpool GI1500PHW8 Ice Cube Maker
Whirlpool GI1500XHB0
Whirlpool GI1500XHB1
Whirlpool GI1500XHB2
Whirlpool GI1500XHB3
Whirlpool GI1500XHB4 Ice Cube Maker
Whirlpool GI1500XHB5 Ice Cube Maker
Whirlpool GI1500XHB6 Ice Cube Maker
Whirlpool GI1500XHB7 Ice Cube Maker
Whirlpool GI1500XHB8 Ice Cube Maker
Whirlpool GI1500XHB9 Ice Cube Maker
Whirlpool GI1500XHN0
Whirlpool GI1500XHN1
Whirlpool GI1500XHN2
Whirlpool GI1500XHN3
Whirlpool GI1500XHN4 Ice Cube Maker
Whirlpool GI1500XHS0
Whirlpool GI1500XHS1
Whirlpool GI1500XHS2
Whirlpool GI1500XHS3
Whirlpool GI1500XHS4 Ice Cube Maker
Whirlpool GI1500XHS5 Ice Cube Maker
Whirlpool GI1500XHS6 Ice Cube Maker
Whirlpool GI1500XHS7 Ice Cube Maker
Whirlpool GI1500XHS8 Ice Cube Maker
Whirlpool GI1500XHS9 Ice Cube Maker
Whirlpool GI1500XHT1
Whirlpool GI1500XHT2
Whirlpool GI1500XHT3
Whirlpool GI1500XHT4 Ice Cube Maker
Whirlpool GI1500XHT5 Ice Cube Maker
Whirlpool GI1500XHT6 Ice Cube Maker
Whirlpool GI1500XHT7 Ice Cube Maker
Whirlpool GI1500XHT8 Ice Cube Maker
Whirlpool GI1500XHT9 Ice Cube Maker
Whirlpool GI1500XHW0
Whirlpool GI1500XHW1
Whirlpool GI1500XHW2
Whirlpool GI1500XHW3
Whirlpool GI1500XHW4 Ice Cube Maker
Whirlpool GI1500XHW5 Ice Cube Maker
Whirlpool GI1500XHW6 Ice Cube Maker
Whirlpool GI1500XHW7 Ice Cube Maker
Whirlpool GI1500XHW8 Ice Cube Maker
Whirlpool GI1500XHW9 Ice Cube Maker
Whirlpool GI15NDXTB0 Ice Cube Maker
Whirlpool GI15NDXTB1 Ice Cube Maker
Whirlpool GI15NDXTQ0 Ice Cube Maker
Whirlpool GI15NDXTQ1 Ice Cube Maker
Whirlpool GI15NDXTQO Ice Cube Maker
Whirlpool GI15NDXTS0 Ice Cube Maker
Whirlpool GI15NDXTS1 Ice Cube Maker
Whirlpool GI15NFLTB0 Ice Cube Maker
Whirlpool GI15NFLTB1 Ice Cube Maker
Whirlpool GI15NFLTBO Ice Cube Maker
Whirlpool GI15NFLTS0 Ice Cube Maker
Whirlpool GI15NFLTS1 Ice Cube Maker
Whirlpool GI15NFRTB0 Ice Cube Maker
Whirlpool GI15NFRTB1 Ice Cube Maker
Whirlpool GI15NFRTBO Ice Cube Maker
Whirlpool GI15NFRTS0 Ice Cube Maker
Whirlpool GI15NFRTS1 Ice Cube Maker
  #2 (permalink)
Old 07-26-2010, 11:53 AM
Junior Member
Default
If anyone else runs into this, replace the pulley, lock nut, and belt. No more trouble.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer Drum has too much play in it Replacement Dryer Repair 0 03-13-2010 08:49 AM
change drive belt and drive pulley clacker48 Washer Repair 2 03-08-2010 11:13 AM
Maytag Drum Drive Belt mdelaurentis223 Washer Repair 2 09-03-2009 04:23 AM
drive belt Klaus Dryer Repair 1 11-03-2008 05:20 PM
Drive belt Pedro D Dryer Repair 3 12-20-2007 07:42 AM
