Levinia
#1 Posted : Thursday, August 7, 2008 5:20:30 PM(UTC)
Levinia
My washer will not stop running water in even with the load setting on low, I have to turn the water off to make it stop running. Then turn the water back on to finish the washing process. I have pushed every button possible and the water will not cut off. Help! Thanks
abadfish66
#2 Posted : Thursday, August 7, 2008 6:39:57 PM(UTC)
abadfish66
does the water run with the machine turned off? If so you have a bad water valve. If it just continues to run when the washer is turned on, you either have a bad pressure switch, or there is some buildup of gunk where the pressure switch attaches to the tub.
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
by Guest 10/26/2023 10:58:17 AM(UTC)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 9/10/2023 4:01:49 PM(UTC)
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
by Guest 8/21/2023 5:22:03 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 7/5/2023 6:03:49 PM(UTC)
Maytag washer control board burns out (Washer Repair)
by Guest 6/20/2023 2:12:48 PM(UTC)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
Maytag Washer shaking - badly (Washer Repair)
by chansman94 1/12/2023 6:47:51 AM(UTC)
Maytag Washer Unbalanced After Tub Bearing & Seal Replacement (Washer Repair)
by Guest 12/26/2022 7:20:26 PM(UTC)
Maytag washer agitates instead of spins (Washer Repair)
by Guest 12/10/2022 11:31:05 AM(UTC)
The pulley on the bottom of my Maytag washer motor has broken. (Washer Repair)
by Guest 9/18/2022 9:05:55 AM(UTC)
