My machine is dripping water at the back of the motor on my washer. Pump and hoses are all dry. Water leaks during was and rinse cycles. The floor is wet every time we run the washer the last week or so. Is there a tub seal at the bottom that could be the culprit? If so is it relatively easy to repair?
