My washer washed the cloths,but when it was time to drain the was, started to make a noise on the contro botton and it didn't wasn to drain the water. I try to go back in to the washing and it will do the washing,but when i put ii to rinse and drain it won't do anything it just makes a noise. I don't know if this is alot of help,but I will like to find out what's going on and if the part can be order?
Originally Posted by: Bfiallos My washer washed the cloths,but when it was time to drain the was, started to make a noise on the contro botton and it didn't wasn to drain the water. I try to go back in to the washing and it will do the washing,but when i put ii to rinse and drain it won't do anything it just makes a noise. I don't know if this is alot of help,but I will like to find out what's going on and if the part can be order? I suggest you remove and check the drain pump for stuck article or siezed shaft. also check the drive coupling for excess wear or damage. if the components check OK and motor only hums in the spin selection I would suspect a damaged contact in the timer assembly
