| » Kenmore Elite Oasis HE won't drain completely |
Model Number: 110.27087604 Brand: Kenmore Age: 1 - 5 years
Kenmore Elite Oasis HE Model #110.27087604. My washer had an error code "ld". I removed the hoses from the pump and discovered loose change in the pump that was probably jamming the impeller. I removed the coins and after fishing more coins out 3 more times the washer started giving me a "sd" code. I checked the impeller and there is definite damage to one of the wings but the others are intact. I ran it through another wash and it again stopped this time with no change in the pump. I ran it through a diagnostic test and received and error code of F32. I pressed the same button for 3 more seconds and C0 displayed and the washer started by its self for a short time the display read C1 - C7 then it stopped. I have run it through another wash cycle and everything seems fine, but at the end of the cycle an inch of water remains in the bottom of the plastic tub. Is this normal? And is it normal that a coin should get under the agitator and into the bottom of the plastic outer tub?
Our Kenmore Oasis did the same thing and now it won't work at all. The computer board appears to be locked up completely. We also removed the pump and hoses because this machine is notorious for sucking loose change into the pump. After doing that (there was no change or anything in the pump), now the machine won't do anything at all. It will come on, you can select you load type, but when you push start nothing happens; the lid won't even lock. It won't turn off either. Normally, the machine will power off if you press "stop" twice but we have to unplug the power cord to get it to turn off. WHAT A PIECE OF CRAP MACHINE FOR NEARLY $1k!!!
| Display Modes | |
| Kenmore Elite Oasis Top Loader will not drain or spin | Rolo1 | Washer Repair | 14 | 06-15-2011 06:32 AM |
| Kenmore Elite Oasis no power | Ron T | Washer Repair | 2 | 05-05-2011 07:36 AM |
| Kenmore Elite Oasis dead | luv2bake | Washer Repair | 4 | 04-09-2010 07:34 PM |
| F1 on Kenmore Elite Oasis | easyrider812 | Washer Repair | 4 | 10-05-2009 10:01 AM |
| Kenmore Elite Oasis: no light | jkok2000 | Washer Repair | 0 | 03-05-2008 03:04 PM |
