Discuss
Unbalance washer won't start, schematic attached
 in
Washer Repair
I have a commercial Maytag coin operated washer that will not work. The "unbalance load" light is on and when
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Unbalance washer won't start, schematic attached
  #1 (permalink)
Old 08-06-2008, 10:08 AM
Junior Member
MikeTD is on a distinguished road
Default Unbalance washer won't start, schematic attached
Brand: Maytag   Age: More than 10 years
I have a commercial Maytag coin operated washer that will not work. The "unbalance load" light is on and when I drop quarters into the mechanism I don't even hear the timer running. I have attached a schematic and circled (in red) where the Unbalanced Load light is. There doesn't appear to be any "unbalance" switch. I was told you can reset the unbalance condition by opening and closing the lid; I've done this but still the problem persists. Any thoughts? Thanks
Ads By Google
  #2 (permalink)
Old 05-31-2010, 12:11 PM
Junior Member
southerngates is on a distinguished road
Default
Mike, I think we are having the same problem as you. Did you ever get a reply or did you get the problem fixed? If you could let us know, we would appreciate it.
  #3 (permalink)
Old 06-01-2010, 04:49 AM
Junior Member
MikeTD1 is on a distinguished road
Default
As I recall it turned out that I needed a new timer assembly for the washing machine. I installed it and everything has worked fine since. Good luck, hope this helps.
  #4 (permalink)
Old 06-01-2010, 10:36 AM
Junior Member
Default
Thanks, we will give that a try. We keep replacing parts to no avail.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer bucket is unbalance by spining make a big noise mani Washer Repair 0 07-24-2009 07:26 PM
washer rocks/unbalance - leveling mechanism failed? alt2mn Washer Repair 2 11-17-2008 08:01 AM
Dryer will not dry when attached to vent. uk2us88 Dryer Repair 6 08-05-2008 05:47 AM
Need wiring schematic for GE washer ibelta Washer Repair 0 03-24-2008 08:10 AM
Need wiring schematic for GE washer ibelta Washer Repair 0 03-21-2008 09:07 AM
