Manufactured 02/2007. Light use by MIL. Fills with water, then loud hum-no agitation. Hum will stop, timer will continue toward rinse, spins well and evacuates water. Hits rinse and fills with water, loud hum, no agitation. Hum will stop, goes into power spin and evacuates water. Shuts off. MIL says while she let the unit hum, it blew a fuse at box. She noticed no overheating or burning smell from the washer. When I tested unit, I did not let it hum very long but moved the timer along to next segment of cycle.
I noticed water pressure is not very good, but she has been using it this way for a couple of years.
Please advise. Thanks for any help.
