Discuss
front loader not draining
 in
Washer Repair
my washing machine spins and washes but does not drain. all the water stays in the tub and the washer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » front loader not draining
  #1 (permalink)
Old 09-13-2007, 12:58 PM
distress distress is offline
Junior Member
distress is on a distinguished road
Default front loader not draining
Model Number: glt1294oeso   Brand: Frigidaire   Age: 1 - 5 years
my washing machine spins and washes but does not drain. all the water stays in the tub and the washer turns of when it goes into draining mode. how can i fix this problem? i am not able to see the model # that well but i think it reads glt1294oeso. thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-14-2007, 03:24 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Run washer in drain, pull bottom front panel and check for voltage to the pump motor, if voltage, remove the hoses to pump and clear out stuff from the pump inlet/outlet. If no voltage, pull out service sheet and check the drain circuit per instructions, should be a chain diagram.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Front Loader Balance problem bersie Washer Repair 2 12-18-2007 04:07 PM
problem with loose drum inside front loader Big G Washer Repair 1 12-18-2007 04:04 PM
no draining after washing. luirod563 Washer Repair 4 10-12-2007 09:38 AM
Maytag Front loader door latch assembly bpcolll Washer Repair 4 08-29-2007 10:55 AM
Front loader not spinning correctly Ferm2374 Washer Repair 0 08-10-2007 06:07 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
