I have a washer dryper combo machine. When the washer is in the spin cycle the tub turns a couple times then you hear a loud noise that the tub is rubbing against something and then it totally stops. The belt is still good but might need replacing after it started smoking when the tub stopped moving. Could this be a bad bearing or something worse? Also is there a manual that might help me change it?
Thanks!
